NETGEAR Forums
This content requires the Macromedia Flash Player Version 7 .
Get Flash Player Version 7 or greater
  #1
Old September 24th, 2009, 02:53 PM
bigjoelee's Avatar
bigjoelee bigjoelee is offline
Junior Member
NETGEAR User
bigjoelee is on a distinguished road
Unhappy WNDR3700 QoS by MAC address
I have been trying to add a QoS priority rule to make sure that my Vonage Phone has priority. I don't believe their tech support knows what QoS is and I have spoken to several of them and they have no idea what the QoS screens look like either. But I have these settings on the front QoS page.
X Enable WMM (Wi-Fi multi-media) Settings (2.4GHz b/g/n)
X Enable WMM (Wi-Fi multi-media) Settings (5GHz a/n)
X Turn Internet Access QoS On
X Turn Bandwidth Control On
Uplink bandwidth: maximum 384 Kbps
Then when I click - Setup QoS Rule
Then I click - Add Priority Rule
I change Priority Category to MAC address
The page changes and adds a - MAC Device List with a table under it that is blank. (side note: clicking the Refresh does not do anything)
QoS Policy for - Von
MAC Address - 00:55:AA:55:A5:A5 (correct one of course)
Device Name - Von1
Priority - Highest
clicking Add or the Apply button blanks this page out, and the rule is not added to the QoS priority list. I can add priorities by ethernet port, On-line gaming, and application. I am running.
Hardware Version WNDR3700
Firmware Version V1.0.4.35NA
GUI Language Version V1.0.0.19
have re-flashed firmware, and reset defaults
netgear case#
10249486
please let me know I'm not crazy!!!
  #2
Old September 24th, 2009, 05:12 PM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is online now
Moderator
NETGEAR Fanatic
jmizoguchi is on a distinguished road
Default Re: WNDR3700 QoS by MAC address
this could be bug in firmware if other options works such port etc in QoS settings.
__________________
VPN Case Study (www.vpncasestudy.com)
Our Second To None VPN Related Setup Case Study
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin"
"Wireless Tips"
Forum Policy
June Mizoguchi-i....@vpncasestudy.com
  #3
Old September 26th, 2009, 06:25 AM
rpw rpw is offline
Junior Member
NETGEAR Newbie
rpw is on a distinguished road
I have the same problem and just opened a case with support.
  #4
Old September 27th, 2009, 07:26 PM
ritchy ritchy is offline
Junior Member
NETGEAR Newbie
ritchy is on a distinguished road
Wink Re: WNDR3700 QoS by MAC address
Hi Guys,
I tried various MAC address with my ACER ASPIRE 4535G with Windows Vista Ultimate SP2 using EE 8.0.6001.18813IC and I had the same problem.
However, I tried different Laptop Computers and all of them are working:
Lenovo SL400 PC1
IE 7.0.6001.18000 - WinXP Home SP3
Firefox 3.0.10 - - WinXP Home SP3
Lenovo SL400 - under VMWare
IE 8.0.6001.18702IC - Vista Ultimate SP1
IE 8.0.7600.16385 - Windows 7 Enterprise
Lenovo SL400 PC2
IE 8.0.7600.16385 - Windows 7 Ultimate
Dell Inspiron 1545
IE 8.0.6001.18813 - Windows Vista Home Premium 64 bit
It is only my ACCER with WinVista SP2 using EE 8.0.6001.18813IC experience the problem.
You may try different different browser or much better to try it with different computer.
  #5
Old September 27th, 2009, 08:36 PM
bigjoelee's Avatar
Junior Member
NETGEAR User
tried on several computers firefox3 and ie 8, some vista some xp all with latest service packs and updates and it doesn't work on any of them for me.
Joseph
  #6
Old September 28th, 2009, 01:26 AM
Junior Member
NETGEAR Newbie
Hi,
I would suggest for you tho reflash the firmware and do a hardware reset then try to add QoS using MAC address. If still not working better return the device, because I also ask my friend to try the same scenario and it is still working.
I think that your device is still under store warranty..
I will look forward to this issue..
Link for firmware and use a hardwired connection.
http://kb.netgear.com/app/answers/detail/a_id/11766
  #7
Old September 28th, 2009, 09:45 AM
bigjoelee's Avatar
Junior Member
NETGEAR User
Well I got an email from a level 2 tech and he asked me to reset defaults and then reflash the firmware again. It sounded like that was his last shot at troubleshooting. He said in his lab that QoS by mac address worked fine. So I guess I'll be rma'ing this one once he gets back tome because trying this as the first thing after a erase then flash still did not fix it. For the time being I move my device to directly connect to the router and gave that port highest priority.
Joseph
  #8
Old September 28th, 2009, 02:47 PM
TallCool1 TallCool1 is offline
Junior Member
NETGEAR Newbie
TallCool1 is on a distinguished road
It's not specific to your unit; Netgear should work harder (try) to duplicate the anomaly. Send them your config file, router serial # and f/w.
--- ATTN NETGEAR FIX YOUR SOFTWARE ----
WNDR3700
s/n # 2181985J xxxx
f/w # WNDR3700-V1.0.4.35NA.img
We can't build a QOS policy for a wireless client / MAC. Nothing appears on the QOS "MAC Device List" table although devices are indeed active and listed under "Attached Devices" on the main menu. A list of clients should immediately appear after selecting "MAC Address" from "Priority Catagory." If the MAC list did populate it should update after hitting refresh. And you can't manually define a QOS policy for a MAC (meaning relying on the MAC Device List and free entering all associated MAC data.)
GET ON IT PLEASE THANK YOU
  #9
Old September 28th, 2009, 03:03 PM
jmizoguchi's Avatar
Moderator
NETGEAR Fanatic
WNDR3700
s/n #
you don't have to send the serial
open the case by going to registration tab at top of this page. support will know what you own by already registered devices.
__________________
"Wireless Tips"
Forum Policy
  #10
Old September 28th, 2009, 03:05 PM
Junior Member
NETGEAR Newbie
I did log a case but perhaps you can delete the serial # from my post thanks!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
