#1
Old July 19th, 2007, 12:42 PM
slickspacey slickspacey is offline
Junior Member
NETGEAR Newbie
slickspacey is on a distinguished road
Default Username and Password don't work
help please. i'm trying to install my wirelss router (WGR614 v6). when i get to the stage where it asks for username and passwrd i put in admin and password respectively but it won't work. can aynone help please?????
  #2
Old July 19th, 2007, 12:53 PM
Mars Mug's Avatar
Mars Mug Mars Mug is offline
Moderator
NETGEAR Fanatic
Mars Mug is on a distinguished road
Default Re: Username and Password don't work
If the default password doesn’t work, and you can’t remember what you changed it to, then you will need to factory reset the router by holding in the small reset button for 30 seconds with the router powered on. This will clear all router settings back to factory defaults, including the password, and you will then have to set up the router again.
__________________
Now posting as Babylon5
  #3
Old July 19th, 2007, 01:23 PM
Junior Member
NETGEAR Newbie
thanks for that. it has worked, but now i can't connect as i don't know the network key. any ideas?
  #4
Old July 19th, 2007, 02:38 PM
Mars Mug's Avatar
Moderator
NETGEAR Fanatic
If you have factory reset the router then the key has gone, and I expect wireless is now turned off by default. So as I said, you need to set it up again, using a wired connection.
__________________
  #5
Old July 19th, 2007, 05:41 PM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Junior Member
jmizoguchi is an unknown quantity at this point
Moving to Super-G (108 Mbps) & 802.11g (54 Mbps) Routers
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
