#31
Old April 9th, 2009, 08:55 AM
superbaby superbaby is offline
Junior Member
NETGEAR Newbie
superbaby is on a distinguished road
Default Re: I Need Help (Cannot Access Router By Typing 192.168.1.1)
also i have tried to do a hard reset which still has not worked...
  #32
Old April 9th, 2009, 09:46 AM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Junior Member
jmizoguchi is an unknown quantity at this point
Quote:
Originally Posted by superbaby View Post
Can someone help me please..? i can not access my netgear DG834GT router. i am with TT and the router is from sky. i have tried inputting the ip 192.168.01 and it comes up with login and password screen. In here i have tried typing in "admin" and "password" but it will not accept it...i have also tried inputting the url http://www.routerlogin.net/basicsetting.htm and the login box appears again but it still will not accept the login details..
can someone help please...?
sky is branded unit. default user/pass is different
user is sky and pass should be password
  #33
Old April 10th, 2009, 05:53 AM
Junior Member
NETGEAR Newbie
Thankyou jmizoguchi for replying, i have tried the details you have suggested but it still wont let me access the router...
  #34
Old April 10th, 2009, 06:00 AM
jmizoguchi's Avatar
Junior Member
if this is SKY and issue with provide unit, I would strongly advised to assist you with issue.
make sure firewall is disabled, use IE7 broswer
  #35
Old April 10th, 2009, 06:18 AM
Junior Member
NETGEAR Newbie
i have disabled my firewall(mcafee 2009) and used IE7, but it still will not let me access the router...could the router itself be at fault?
  #36
Old April 10th, 2009, 09:51 AM
jmizoguchi's Avatar
Junior Member
do have other source of pc you can try with?
  #37
Old April 10th, 2009, 10:48 PM
Junior Member
NETGEAR Newbie
i have tried on my hp laptop and it is just the same. it wont let me get access to the router.
  #38
Old April 11th, 2009, 12:31 AM
Mars Mug's Avatar
Mars Mug Mars Mug is offline
Moderator
NETGEAR Fanatic
Mars Mug is on a distinguished road
According to this, for a Talk Talk supplied router the user/password are both the same i.e. user = admin / password = admin
http://www.talktalkmembers.com/content/view/61/68/
__________________
Now posting as Babylon5
  #39
Old April 11th, 2009, 05:46 AM
Junior Member
NETGEAR Newbie
i am with talktalk but the router is a sky branded DG834GT. i have tried admin/password also sky/password to access it but it wont let me in. resetting the router has no effect aswell...
  #40
Old April 11th, 2009, 07:24 AM
jmizoguchi's Avatar
Junior Member
if you take 2nd PC and still has same issues, I would say check sky forum /support.
other way is to use recovery tool and reload the netgear firmware instead
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
