#11
Old November 19th, 2007, 06:10 PM
jaycoute jaycoute is offline
Junior Member
NETGEAR Newbie
jaycoute is on a distinguished road
Default Re: WGR614 port forwarding
I've been having a very similar problem with port forwarding the last couple of days. I recently changed from using a Linksys wired router to a Netgear WGR614v6. As a previous poster reported I can access my Apache server by using the LAN address (192.168.1.5) but not the WAN address. I upgraded the firmware to the latest (V2.0.19_1.0.19NA) and that didn't help.
I does seem to be working now and what seemed to work was adding a second "dummy" custom service on the port forwarding page. In particular, I wanted the following port to actually work but it wouldn't when it was the only custom service defined:
altHTTP 8080 8080 192.168.1.5
...so I added another "dummy" custom service just on a lark:
dummy 8888 8888 192.168.1.5
Now the "real" custom service (port 8080) seems to be working fine. When I take out the "dummy" service the real one stops working. It's goofy and I don't have an explanation for why it works but it seems to. Also, the loopback apparently works fine with this router because I can go from LAN->WAN->LAN without a problem now that the forwarding is working. I even logged on to a remote system and tried it from there successfully. So maybe this hack will work for you.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
