#1
Old April 15th, 2008, 04:27 AM
scooterlord scooterlord is offline
Junior Member
NETGEAR Newbie
scooterlord is on a distinguished road
Default removing antenna in dg834g v4
hello everyone! well, I bought a new 5dbi antenna for my router and can't see of a way to remove the oem antenna! any ideas, instructions? pics welcome
thanks
  #2
Old April 15th, 2008, 07:19 AM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Junior Member
jmizoguchi is an unknown quantity at this point
Default Re: removing antenna in dg834g v4
unfortunately most home end router's antenna do not come off or unscrew.
most of those uses that come unscrew uses RP-SMA connector
http://wireless.gumph.org/content/3/...onnectors.html
if you really want to use external antenna. you have to solder to the board
  #3
Old April 15th, 2008, 04:29 PM
Junior Member
NETGEAR Newbie
well that's bad news. first because I already bought an antenna, but mainly because my hopes for better signal are lost.
I am positive that I read that its antenna was detachable though. are you absolutely sure that it cannot be done in any other way than soldering the new one on?
  #4
Old April 15th, 2008, 04:32 PM
jmizoguchi's Avatar
Junior Member
I'm pretty sure.
If you can unscrew then not. Simple deal
  #5
Old April 24th, 2008, 11:53 PM
mrniceguy mrniceguy is offline
Junior Member
NETGEAR Newbie
mrniceguy is on a distinguished road
Hello,
i discovered the same one.
for me is it very unfortunate, because i brought the dg834g v4 and the ANT24O5 new. according to the "antenna guideline" on the german netgearsite, its possible to use the dg834g with the antenna. there is no reference, that the antennas of the v4 are not removeable.
so, which one of the home-routers have an unscrewable antenna?
thanks a lot
  #6
Old April 25th, 2008, 06:45 AM
fihart's Avatar
fihart fihart is offline
Senior Member
NETGEAR Addict
fihart is on a distinguished road
DG834GT has removable antenna.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
