#11
Old January 30th, 2009, 12:09 PM
Ricker Ricker is offline
Junior Member
NETGEAR Newbie
Ricker is on a distinguished road
Default Re: HDMI Issues - Post HERE
Logged a report with support, Waiting a response.
  #12
Old January 31st, 2009, 01:12 AM
StephenB StephenB is offline
Senior Member
NETGEAR Fanatic
StephenB is on a distinguished road
Quote:
Originally Posted by Ricker View Post
I orginaly posted this issue on Beta forum as I thought this issue was because I updated the firmware. But know I release this is a HDMI issue. My problem is no audio on MP4 films .. MP3 works fine as does VOB files. IS this a problem with the EVA it self ? or with a particular batch ?
IF the MP4 has HE AAC audio (or AAC with SBR), then the EVA cannot play it. Mediainfo (http://mediainfo.sourceforge.net/en/Download) will give you the codec information, if you like you can post the text output here (in a new thread) and I can look it over.
  #13
Old January 31st, 2009, 07:30 AM
Junior Member
NETGEAR Newbie
Please see below the info you requested. Strange thing is the audio is outputed on the RCA and SCART connectors just not the HDMI. Also MP3 and VOB work fine throught HDMI.
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 54mn
Bit rate mode : Constant
Bit rate : 132.3 Kbps
Nominal bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 24.0 KHz
Resolution : 16 bits
Stream size : 108 MiB (15%)
Encoded date : UTC 2008-02-06 01:51:12
Tagged date : UTC 2008-02-06 01:51:12
  #14
Old January 31st, 2009, 12:12 PM
Senior Member
NETGEAR Fanatic
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 54mn
The sampling rate is unusual - 24 kHz. That may be the problem. I'm on the road, so it will take about a week before I can test it.
  #15
Old January 31st, 2009, 12:37 PM
Senior Member
NETGEAR Fanatic
Quote:
Forgot to mention - this issue could actually be in your TV - it may be unable to play 24 kHz audio.
  #16
Old February 1st, 2009, 08:44 AM
Junior Member
NETGEAR Newbie
Thanks StephenB.. I checked the spec. for my TV and you are correct it does not accept this audio sample rate. I tried a new file with higher sample rate and it WORKED ! Result .. thanks again.
  #17
Old February 1st, 2009, 11:00 AM
AltGr's Avatar
AltGr AltGr is offline
Senior Member
Advanced NETGEAR User
AltGr is on a distinguished road
You can transcode audio only with mediacoder. It takes some 15 minutes, and you can only change the sampling rate if you wish. There is options for codec, bitrate, channels etc. too.
Cheers AltGr
__________________
Cat5 wired gigabit network - W7 Ultimate x64 -> no DEW - D-Link DNS-323 NAS 2,25TB - NetGear ProSafe 16 port miniswitch GS116 - IPs by Telewell TW-EA514 DHCP - Eva8k via HDMI to Sony STR-DG820 via HDMI to Sony KDL-46X3500 - FW 2.1.78 IS
  #18
Old February 12th, 2009, 11:06 PM
BassMaster BassMaster is offline
Junior Member
NETGEAR Newbie
BassMaster is on a distinguished road
Hi!
I have some troubles with HDMI- I`m using Acer DLP projector, which original resolution is 1280*720, @60 Hz, and it support 1080i/p with downscalling. Usually i watch EVA on standard TV using composite video and switch EVA to HDMI to watch movies. After pressing TV Mode (Next mode 720P) emage on TV disappear, and appears on projector only for a moment, then missing from both TV and projector. I must press many times TV MODE and sometimes must restart EVA for correctly switching to HDMI. Another home eqipment, such as Yamaha DVD-s 661 can automatically identify parameters of my projector and works fine. Looks like projector can`t synchronize with EVA.
  #19
Old March 4th, 2009, 11:46 AM
corbin1747 corbin1747 is offline
Junior Member
NETGEAR Newbie
corbin1747 is on a distinguished road
did you ever get a reply from tech support about the HDMI issue? i think one way i manged to sort out the HDMI problem is to unplug and plug back in the HDMI cable while the eva is on.. but after a while it seems that it created yet another problem... the damn thing frooze... so i had to re-flash it to get it back to normal....
  #20
Old March 12th, 2009, 04:21 AM
Junior Member
NETGEAR Newbie
Hi again!
I try number of firmware and see common trouble- when EVA boots, it turns preferably to HDMI (if any device connected to it) and try to read its resolution capabilities. In 50% caces after boot at first time picture directed to HDMI correctly. But if i change input on projector or press "resync" on it, EVA switch to composite out and show "Setting TV mode 576i" message there.After 5 seconds picture dissapears from composite and appears on HDMI only for a moment. Projector show info:HDMI 1280*720,60Hz. Then picture re-appears on composite out, "Setting TV mode 576i" and this cycle repeats again and again..Can you imagine what my family said when we try to watch a movie at evening and I jumping with EVA remote a lot of time to switch it from CRT tv to big screen... If PnP on HDMI not works correctly maybe let USER always manually switch TV mode? Please think about before next FW release
___________________________
EVA8000, DNS-323 1 TB, ACER DLP PH530
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
