#41
Old September 25th, 2011, 01:40 PM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Senior Member
NETGEAR Fanatic
jmizoguchi is on a distinguished road
Default Re: RP614v4 Failures
some communication between the ISP and router for renew/release
__________________
VPN Case Study (www.vpncasestudy.com)
Our Second To None VPN Related Setup Case Study
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin"
"Wireless Tips"
Forum Policy
June Mizoguchi-i....@vpncasestudy.com
  #42
Old September 25th, 2011, 05:52 PM
Steve777 Steve777 is offline
Junior Member
Steve777 is on a distinguished road
Thanks. Lots of info here, I will need to go over it and see if I can get to the bottom. But it sounds like I may need bridge mode in my DSL modem.
One complicating factor (perhaps) is that the configuration of my system is:
DSL modem -> VOIP box -> RP614v4. This is how the VOIP people want things configured (no doubt so that they can decide who get the bandwidth). I presume it also means that the RP614 was getting its DCHP lease from the VOIP box not the DSL modem.
I would imagine this is not that unusual a configuration, but I did not see any mention of it in the links you provided. Does it change anything here???
TIA
  #43
Old September 26th, 2011, 04:24 AM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
I would put voip behind the rp and use port forwarding or DMZ for voip
__________________
"Wireless Tips"
Forum Policy
  #44
Old March 26th, 2012, 09:45 PM
dfhepner dfhepner is offline
Junior Member
dfhepner is on a distinguished road
Default Re: RP614v4 - pwr light only, third router
Quote:
Originally Posted by nobel_nomar View Post
Anyone that is having similar issues, please post in this thread.
Stickied.
I had the same problem, but after about 6 months of 24/7 use. I checked the unloaded power supply out put and it was 5V. I then check the power supply while it was powering the RP5614v4 and found that it was only 3.9V. I had another power supply that was rated for 2A out so I used that and now the unit is working again. I expect that the problems that people have been seeing is due to the power supply failing
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
