#11
Quote:
__________________
VPN Case Study (www.vpncasestudy.com) Our Second To None VPN Related Setup Case Study "One Stop Solution To Your Netgear VPN Connectivity" *Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support] Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin" "Wireless Tips" Forum Policy June Mizoguchi-i....@vpncasestudy.com |
#12
Quote:
If you already did a hard reset then the problem is still there. Please use the CD to perform a Firmware Recovery, after the recovery. Setup the router and get it online then download the latest firmware and do the manual upgrade. note: Router should be hardwired to the computer.
#13
I was in the same boat, without a CD to recover from. Here's the solution, as given to me by Netgear (and it worked). It requires a Windows machine hooked up to your router, and some way to download the following files and get them to that machine.
#14
This helped a lot! Have been trying to set it up for quite some time now and the solution mentioned above actually worked!! Thanks!!!
#15
Netgear use to provide the Recovery CD downloadable from their website, as it was easier to use than tftp.
| Thread Tools | |
| Display Modes | |
