#11
Old March 27th, 2010, 02:13 PM
Paul1973 Paul1973 is offline
Member
NETGEAR Newbie
Paul1973 is on a distinguished road
Default Re: Enabling Guest net disables wifi router radio
I've been running a guest network on the 2.4 radio since I bought thhis router. It works just as well with .55 as it has with any firmware.
  #12
Old March 29th, 2010, 07:39 PM
Chameleon Chameleon is offline
Junior Member
Chameleon is on a distinguished road
I can confirm this condition on a brand new router running V1.0.4.55NA firmware.
Disabling the Guest WiFi network allows the primary WiFi network to operate. I did not check to see if the inverse was true, nor did I check to see if both WiFi networks were operational on the stock firmware.
This situation is acceptable for now, but I am hopeful for a resolution in the near future.
  #13
Old April 1st, 2010, 05:23 PM
raging_blitzer raging_blitzer is offline
Junior Member
NETGEAR Newbie
raging_blitzer is on a distinguished road
I have this unit too but dont have the same problem. it could be possible that it is like a bad batch of routers as this has just came out of nowhere. also a reason why tech support would be surprised to hear this when you call. to help NETGEAR with this issue, i would suggest you post the serial numbers of your router if you have this issue.
of course please make sure they are already registered under your name before posting them
Register here before posting the serial number on the forum: https://my.netgear.com/registration/login.aspx
  #14
Old April 2nd, 2010, 08:11 PM
sh00t4par sh00t4par is offline
Junior Member
sh00t4par is on a distinguished road
I also can confirm this problem. I just got my WNDR3700 from Amazon and all was well until I set up the guest network which was a big selling point for me. Radios get turned off and when I manually turn them back on using the button on the front of the router I can't connect. I am running the latest firmware V1.0.4.55NA. This is very dissapointing since I am coming from Linksys and never had an issue with them.
  #15
Old April 2nd, 2010, 10:00 PM
Junior Member
I setup another one of these routers today for a different client.
I verified that the guest WiFi network knocks out the regular WiFi network on the stock V1.0.4.49NA firmware as well.
Something is very wrong here.
  #16
Old April 2nd, 2010, 11:11 PM
Junior Member
NETGEAR Newbie
once again, please be reminded that not everyone is having this issue (especially those who have had it for a long time) so most probably this could be a batch that were manufactured on a specific date. This post has just been raised this March and only a number of users are reporting it that is why NETGEAR may still be unaware.
NETGEAR could still be investigating this issue and I am sure that with your help this will be addressed accordingly. please post your serial numbers here together with the store where you purchased them from so we could contribute in collating the said issue. It is very obvious that this issue is mostly experienced by users who had just purchased the unit so it could just be a bad batch.
Have a great day everyone!
  #17
Old April 2nd, 2010, 11:25 PM
RoderickGI RoderickGI is offline
Senior Member
NETGEAR Expert
RoderickGI is on a distinguished road
As Netgear don't monitor this forum, it would make more sense to raise a support ticket with them at mynetgear.com. They will collate the occurances, I'm sure, at that way the serial number of the routers isn't posted in a pblic forum.
Cheers.
  #18
Old April 3rd, 2010, 05:06 AM
sammia sammia is offline
Moderator
NETGEAR Newbie
sammia is on a distinguished road
You may contact NETGEAR support for them to verify other needed details (serial numbers, store name where the device purchased, et.al.). This could be an isolated case for some users and this is worth investigating.
  #19
Old April 3rd, 2010, 03:28 PM
Senior Member
NETGEAR Expert
Oops. Yeah, it is http://my.netgear.com to create a "new online technical submission request", where you can submit all the details of the problem, and it will be automatically linked to the serial number of your registered product.
I forgot the "." in there.
Then plain old Netgear Support has the Knowledgebase, FAQ and stuff, but is not linked to your specific unit.
Post editing would be so handy. Perhaps I should just proofread my posts a bit better before posting.
  #20
Old April 3rd, 2010, 04:25 PM
CoyoteDen CoyoteDen is offline
Junior Member
NETGEAR Newbie
CoyoteDen is on a distinguished road
Question Re: Enabling Guest net disables wifi router radio
I'm definitely not having this problem. 1.0.4.55NA
b/g/n ssid is coyote_den WPA/WPA2
a/n ssid is coyote_den_a WPA2
guest b/g/n is coyote_den_public. Tried Open,WEP,and WPA modes.
Everything works. WLANs do go down after enabling guest network, but they come back up within a minute. (Takes longer when enabling guest than when disabling..)
My a/b/g/n laptop can connect to all of the networks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
