#31
Quote:
If it is a hardware problem it does not apply to all WNDR3700's
__________________
I don't work for Netgear. My name is Andy. |
#32
I'm having the exact same issue. Wifi works fine but as soon as I enable the guest network, the check boxes "Enable Wireless Router Radio" in Wireless Settings un-check and I loose all wifi access.
#33
The response I received from support is basically they are collecting information now.
So, I guess we'll see what happens. |
#34
Maybe it's time to go back to my old router and return this one to Amazon?
#35
Has anyone bought their router at a best buy recently and had this problem?
#36
I purchased this router from best buy two days ago and I'm having this problem. When I enable guest mode, the wireless radio shuts off.
#37
I got the same problem: Whenever I enable the Guest Network, then the Wireless Radio will go off.
Spend a lot of hours on the configuration since I thought that I did not config it correctly. Waste of my time. How long did this product come out to the market, anyone know??? |
#38
I returned my router that I got from fry's and went to best buy. I still have the same problem.
#39
I have replaced mine with another one but as expected, the problem is still there. The shop is allowing me to return the router by next Monday...
What should I do.... ![]() When will Netgear resolve this problem?! ![]() Or even worst, will they not able to fix it?!
#40
Facing the same problems. Customer support told me to return it and get a new one.
Don't see the point if they all don't work!! |
| Thread Tools | |
| Display Modes | |
