#21
Old March 18th, 2010, 05:39 AM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is online now
Senior Member
NETGEAR Fanatic
jmizoguchi is on a distinguished road
Default Re: FVG318 Remote Desktop issue
Quote:
Using IPsec SA configuration: 10.0.0.0/24<->0.0.0.0/0 from Ebbe˙˙˙
0.0.0.0... does not look right
__________________
VPN Case Study (www.vpncasestudy.com)
Our Second To None VPN Related Setup Case Study
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin"
"Wireless Tips"
Forum Policy
June Mizoguchi-i....@vpncasestudy.com
  #22
Old March 18th, 2010, 07:10 AM
Ebbe Ebbe is offline
Junior Member
NETGEAR Newbie
Ebbe is on a distinguished road
No, but then the FVG generates a policy:
2010-03-18 : INFO: No policy found, generating the policy : 192.168.1.100/32[0] 10.0.0.0/24[0] proto=any dir=in
which seems right to me? The laptop (external) have 192.168 and the local computer have 10.0.
  #23
Old March 18th, 2010, 08:16 AM
adit's Avatar
adit adit is offline
Moderator
NETGEAR Fanatic
adit is on a distinguished road
Like I said in my previous post, post screenshots for review.
__________________
Forum Rules - Post Screenshots on ImageShack for Free - Firmware Upgrade Procedure
Online Subnet Calculator - LAN Subnets NOT to Use - SA Lifetime Guidelines - Hex/IP Converter
Free Netgear Support Online Trouble Ticket Submissions 1-888-NETGEAR 4,3 Netgear Knowledge Base
VPN Router Support, Interface Demos,and Marketing Pages:
SRX5308 S M - FVS336G S I I M - FVS318G S M - FVS318N S M - FVS338 S I I M - SRXN3205 S M -
VPNG01/5L S M - FVS318 S I I M - DGFV338B S I M - FVG318 S I I M - SSL312 S I M - FVX538 S I I
FVS114 - FVS124G - FVS328 - FVL328 - FWG114P - GPL Firmware Code - MyOpenRouter - VPNC Docs
Click Here for my VPN Client and Mode Config VPN Client Tutorials
ProSecure STM/UTM Appliance User Forum - Prosecure Marketing Website
Good Luck...ADIT
FYI - I am a Reseller and not employed by Netgear
  #25
Old March 18th, 2010, 09:49 AM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
I can't look the screenshot since I'm on my phone but
0.0.0.0 entry is not right
I have 100%. Working order case studies
__________________
"Wireless Tips"
Forum Policy
  #26
Old March 18th, 2010, 04:26 PM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
suggestion is to look at my case study
http://vpncasestudy.com/casestudy/FV...casestudy.html
__________________
"Wireless Tips"
Forum Policy
  #27
Old March 18th, 2010, 09:11 PM
adit's Avatar
Moderator
NETGEAR Fanatic
Ebbe and Via are not FQDN's. Use what is in the tutorial.
shrew1 - set the Local IP to 192.168.100.1
__________________
Good Luck...ADIT
  #28
Old March 18th, 2010, 11:51 PM
Junior Member
NETGEAR Newbie
Ehmmm. I just found out why I couldn`t connect to my local network through the FVG. An IP-phone box acted as another NAT device in front of the FVG. This box has been disabled for a period of time, but has started to work after a power-reset. Sorry. I have disconnected this box and are now able to connect to my network from internet. (Using settings like screenshots) But still not able to connect to the FVS from my local net.
  #29
Old March 18th, 2010, 11:59 PM
Junior Member
NETGEAR Newbie
This is the log from the remote FVS:
[2010-03-18 23:53:09][==== IKE PHASE 1(from 90.149.XXX.XXX) START (responder)
[2010-03-18 23:53:09]**** RECEIVED FIRST MESSAGE OF AGGR MODE ****
[2010-03-18 23:53:09]<POLICY: > PAYLOADS: SA,PROP,TRANS,KE,NONCE,ID,VID,VID,VID,VID,VID,VID, VID,VID,VID,VID
[2010-03-18 23:53:09]<LocalRID> Type=ID_FQDN,ID DATA=Ebbe
[2010-03-18 23:53:09]<RemoteLID> Type=ID_FQDN,ID DATA=Ebbe
[2010-03-18 23:53:12]<POLICY: Ebbe> PAYLOADS: SA,PROP,TRANS,KE,NONCE,ID,HASH,VID,NATD,NATD,NATD
[2010-03-18 23:53:12]**** SENT OUT SECOND MESSAGE OF AGGR MODE ****
[2010-03-18 23:53:12]**** RECEIVED THIRD MESSAGE OF AGGR MODE ****
[2010-03-18 23:53:12]<POLICY: Ebbe> PAYLOADS: HASH,NATD,NATD
[2010-03-18 23:53:12]**** AGGR MODE COMPLETED ****
[2010-03-18 23:53:12][==== IKE PHASE 1 ESTABLISHED====]
[2010-03-18 23:53:12]**** RECEIVED INFORMATIONAL EXCHANGE MESSAGE ****
When I try to ping:
[2010-03-18 23:53:35][==== IKE PHASE 2(from 90.149.XXX.XXX) START (responder)
[2010-03-18 23:53:35]**** RECEIVED FIRST MESSAGE OF QUICK MODE ****
[2010-03-18 23:53:35]<POLICY: Ebbe> PAYLOADS: HASH,SA,PROP,TRANS,NONCE,ID,ID
[2010-03-18 23:53:35]**** FOUND IDs,EXTRACT ID INFO ****
[2010-03-18 23:53:35]<Initiator IPADDR=10.0.0.10>
[2010-03-18 23:53:35]<Responder IPADDR=192.168.1.0 MASK=255.255.255.0>
[2010-03-18 23:53:35]**** SENT OUT SECOND MESSAGE OF QUICK MODE ****
[2010-03-18 23:53:35]**** RECEIVED THIRD MESSAGE OF QUICK MODE ****
[2010-03-18 23:53:35]**** QUICK MODE COMPLETED ****
[2010-03-18 23:53:35][==== IKE PHASE 2 ESTABLISHED====]
So it seems that the tunnel is up, but my FVG will not permit ping or RDP
  #30
Old March 19th, 2010, 02:02 AM
GuyAdams's Avatar
GuyAdams GuyAdams is offline
Moderator
NETGEAR Addict
GuyAdams is on a distinguished road
Are there any software firewalls on the client/s you are trying to ping or RDP, if so you will need to adjust them to accept traffic from your other subnet.
Thanks
__________________
Guy Adams
Check out my blog 'Guy Adams on Technology' here (external link)
Forum Rules - Post screenshots for free
VPN Tutorials, Tips & Tricks - ProSafe Firmware Upgrade - Interface Demo's
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
