#11
Um, okay?
I agree with Fordem but I'm sure Maninpc hasn't carried all his devices out to the bookstore cafe'...which is why I said the router is assigning these addresses randomly because of the way it is programmed. Yes it is possible for a PC to carry with it a previously assigned address, yes it is possible for devices to get that same address or the next available but if there were no other reason for PCs to get the next available address, starting with the first numerically available within the DHCP address range...then what could it be? (1) Either the router is programmed to do this in this manner or (2) People outside the router are hopping on and surfing or (3) Address reservation has already been used for that device. If it is the router programming, nothing can be done but new firmware. If it is people hopping on, then Maninpc can see this under "Attached Devices" and then he needs to setup some better security. If it is Address Reservation, he can simply change the addresses to be in numerical order...either starting with the first available in the address range or number each/some/all devices outside the address range. Either way will work. I recommend using Address Reservation. |
#12
Simply powering off the router and PCs then powering on again will clear most of those possible issues.
By the way I've never seen a Netgear router randomly issuing IP addresses from the DHCP pool, and my '3700 doesn't.
__________________
I don't work for Netgear. My name is Andy. |
#13
Yes, power cycling devices should clear the issue...it does with other routers. But with this router, it works 'some' of the time.
I can't explain why, but my WNDR3700 does randomly assign addresses. Atleast, it did before I started using DHCP Reservation. Other routers I've owned did not have this behavior. |
#14
Thanks all for your input, However in my past experience a DHCP router assigns ip address in synchronized order. 192.X.X.2, then next device would get 192.x.x.3, and so on. I have never seen a dhcp router just throw out any random number like i am getting.
#15
Quote:
It might be a good idea to power off the router/PC just to clear the tables so that we get a fresh start. It might also be a good idea to run a network scanner to scan the subnet (e.g. 192.168.1.1 to 192.168.1.254) and see what's there, I use this one; http://www.softperfect.com/products/networkscanner/
__________________
#16
Quote:
It is not a failure of the unit, and your never having seen it happen, doesn't change that - if you want specific addresses you must either assign static addresses or use DHCP reservation.
__________________
Give a man a fish, feed him for a day Teach a man to fish, feed him for life. |
#17
if router is setup to use 192.168.1.2~192.168.1.254/ 255.255.255.0 , DHCP will not randomly pushes other LAN subnet as such as 192.168.0.x to DHCP client .
__________________
VPN Case Study (www.vpncasestudy.com) Our Second To None VPN Related Setup Case Study "One Stop Solution To Your Netgear VPN Connectivity" *Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support] Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin" "Wireless Tips" Forum Policy June Mizoguchi-i....@vpncasestudy.com |
#18
Quote:
![]() Quote:
![]() Quote:
#19
Quote:
Maninpc said Quote:
#20
Quote:
Quote:
__________________
| Thread Tools | |
| Display Modes | |
