#21
Old August 2nd, 2010, 12:45 PM
mklc mklc is offline
Junior Member
NETGEAR Newbie
mklc is on a distinguished road
Default Re: Which "revision" do I have of the WNDR3700?
I have a WNDR3700-100PES.
How about 100-13948-01R14?? Is this a bad revision?
Sometimes my wireless drops and it looks like the wireless loses his strenght.
I`m worried now when i would flash dd-wrt on it. That i will brick/destroy it because of the wireless issue.
  #22
Old August 2nd, 2010, 10:10 PM
mastershake mastershake is offline
Senior Member
NETGEAR Expert
mastershake is on a distinguished road
i would not flash it on it. there are still bugs they need to work out. and none are actually "bad" its just some work better than others at certain things
  #23
Old August 3rd, 2010, 04:35 AM
htismaqe's Avatar
htismaqe htismaqe is offline
Senior Member
NETGEAR Addict
htismaqe is on a distinguished road
So is the revision number not on the router anywhere? Do I have to get the box out of storage?
  #24
Old August 3rd, 2010, 05:40 AM
Widber Widber is offline
Junior Member
Widber is on a distinguished road
Quote:
Right.
At least my, one of the very first (german) revision 01R10 has this number on the package only. And not on the router.
  #25
Old August 3rd, 2010, 05:54 AM
gate1975mlm gate1975mlm is offline
Junior Member
NETGEAR User
gate1975mlm is on a distinguished road
What about "01R8"?
Good or bad?
  #26
Old August 24th, 2010, 08:01 AM
cfphoenix cfphoenix is offline
Junior Member
cfphoenix is on a distinguished road
My new WNDR3700 R17 which came in a blue/purple box has the Revision 4 board - no wonder there is no difference in terms of performance between the R17 and R21, which have the same board.
  #27
Old September 1st, 2010, 05:12 PM
ZzBloopzZ ZzBloopzZ is offline
Junior Member
NETGEAR Newbie
ZzBloopzZ is on a distinguished road
Are you 100% positive the R17 is Revision 4? Reason I ask, is because I am still with in the 30 day window and my local BB has R21's now.
Thanks!
  #28
Old September 9th, 2010, 12:00 PM
jwolf1 jwolf1 is offline
Junior Member
NETGEAR Newbie
jwolf1 is on a distinguished road
I just received a WNDR37AV from Newegg.com. The box is black with a blue top side. Box states "WNDR 37AV" with wireless N not draft-n. Neither the box nor router contain a revison number, i.e; 02R1 or 01R21. The router shipped with .49NA firmware which I updated to .68NA. I called support to find out my version based on the serial number but they were less than helpful. They claimed all of the routers were version 1 and that a revision number does not even exist. Any ideas if I have the latest revision with the 4 board?
  #29
Old September 23rd, 2010, 02:24 PM
cc999 cc999 is offline
Senior Member
Advanced NETGEAR User
cc999 is on a distinguished road
What about "01R8"?
I ALSO have this one............Anyone?
  #30
Old September 23rd, 2010, 05:50 PM
jlewter jlewter is offline
Senior Member
NETGEAR Addict
jlewter is on a distinguished road
Quote:
Support told me customers are not allowed to know the revision number, and if I wanted to know that I should return mine for another one so I could get the box info!!!
I dont know why they wont do it, my guess is that it has to do with the dead 2.4ghz routers out there, if failure rates are above about 2-3% then people having the ability to know that they have a router in that "zone" of production would likely see them doing a lot of RMA's and that's something that they will want to avoid..
I would welcome anyone passing this up to support if they wish to object to this being the possible case.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
