#11
Old August 31st, 2010, 03:18 PM
adit's Avatar
adit adit is offline
Moderator
NETGEAR Fanatic
adit is on a distinguished road
Default Re: Classical Routing
You would be better off with a VLAN switch. You are really not protecting the work PC with your setup.
The 318 will work in Classical Routing Mode.
Your problem is Routing from LAN (2.x) to LAN (1.x) to the Internet.
Post screenshots of what you have setup.
Ping and Traceroute from 2.x to 1.x and 2.x to 4.2.2.2 and list the results.
Read my LAN Subnets NOT to Use note.
__________________
Forum Rules - Post Screenshots on ImageShack for Free - Firmware Upgrade Procedure
Online Subnet Calculator - LAN Subnets NOT to Use - SA Lifetime Guidelines - Hex/IP Converter
Free Netgear Support Online Trouble Ticket Submissions 1-888-NETGEAR 4,3 Netgear Knowledge Base
VPN Router Support, Interface Demos,and Marketing Pages:
SRX5308 S M - FVS336G S I I M - FVS318G S M - FVS318N S M - FVS338 S I I M - SRXN3205 S M -
VPNG01/5L S M - FVS318 S I I M - DGFV338B S I M - FVG318 S I I M - SSL312 S I M - FVX538 S I I
FVS114 - FVS124G - FVS328 - FVL328 - FWG114P - GPL Firmware Code - MyOpenRouter - VPNC Docs
Click Here for my VPN Client and Mode Config VPN Client Tutorials
ProSecure STM/UTM Appliance User Forum - Prosecure Marketing Website
Good Luck...ADIT
FYI - I am a Reseller and not employed by Netgear
  #12
Old August 31st, 2010, 03:25 PM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Senior Member
NETGEAR Fanatic
jmizoguchi is on a distinguished road
I would agree on vlan switch too
__________________
VPN Case Study (www.vpncasestudy.com)
Our Second To None VPN Related Setup Case Study
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin"
"Wireless Tips"
Forum Policy
June Mizoguchi-i....@vpncasestudy.com
  #13
Old September 1st, 2010, 05:33 AM
prindte prindte is offline
Junior Member
NETGEAR Newbie
prindte is on a distinguished road
Are you talking about using a VLAN switch in place of the 318g, or are you talking about using a VLAN switch with the 318g?
I was thinking of using a VLAN switch instead of the router, BUT the Uverse router would still try to assign IPs to the PCs that are on the 192.168.2.x segment even if they were in a seperate VLAN wouldn't it?
I saw your post on subnets NOT to use, but the again the Uverse router only gives me options to use subnets in that list!
  #14
Old September 1st, 2010, 05:35 AM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
there is NO VLAN on 318G
__________________
"Wireless Tips"
Forum Policy
  #15
Old September 1st, 2010, 05:50 AM
adit's Avatar
Moderator
NETGEAR Fanatic
You would use the VLAN switch instead of the 318.
The VLAN switch will serve it's own DHCP (or you can use the server) and block DHCP from the Uverse router. You'll have to isolate the IP's based on the range you can use.
You may be limited to using IP's in the 1.x range (split the IP's up, half for each, 1-128 & 129-256) due to limitations in the Uverse router. You'll have to check the options in the Uverse DHCP server.
I've never been inside of one so I don't know the capabilities. Post screenshots of each config page in the Uverse if you'd like us to take a look at it.
__________________
Good Luck...ADIT
  #16
Old September 1st, 2010, 05:56 AM
Junior Member
NETGEAR Newbie
Thank you ADIT, I will give the VLAN switch setup a shot tonight. I have a Netgear GS108T that I can use.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
