#11
Old January 7th, 2011, 11:07 PM
CVA077 CVA077 is offline
Junior Member
NETGEAR Newbie
CVA077 is on a distinguished road
Default Re: N300 router problems...
We are having the same problems neither Ipod or laptop will wireless connect
using a WRN2000. Let me what you need.
  #12
Old January 8th, 2011, 04:08 AM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Junior Member
jmizoguchi is an unknown quantity at this point
did you try what is suggest prior post of mine
  #13
Old June 27th, 2011, 01:48 AM
BILL181 BILL181 is offline
Junior Member
NETGEAR Newbie
BILL181 is on a distinguished road
Hi I am having the same issue. Brand new DGN2200 / N300, Brand new Toshiba notebook, the computer shop said was compatible. They even set it all up in the shop so it worked before i took it home. Get it home, the laptop can see the wireless signal, but go and connect = " Windows was unable to connect to NETGN300". Any ideas other than drive 1 hour to shop, leave it there and drive back etc.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
