#21
Old January 21st, 2011, 09:32 AM
jlewter jlewter is offline
Senior Member
NETGEAR Addict
jlewter is on a distinguished road
Default Re: open port
Quote:
Originally Posted by andrewcall View Post
i really don't know what you guys just said
basicly i need to open port 123 UDP
i have a vodafone sure signal box which wont work aparently unless this port is open
There's a difference between being open and being forwarded.
The port is not "closed" or "blocked".. It's "open" and not "forwardable" through user settings.
NTP works for everyone on here and it's UDP port 123.
  #22
Old January 21st, 2011, 10:08 AM
htismaqe's Avatar
htismaqe htismaqe is offline
Senior Member
NETGEAR Addict
htismaqe is on a distinguished road
You shouldn't need to port forward UDP 123.
The Vodafone box uses NTP to sync time - so do Windows and Linux PCs and all kinds of other devices.
If it wasn't functioning correctly, there would be literally thousands of posts about it.
  #23
Old January 21st, 2011, 10:14 AM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Junior Member
jmizoguchi is an unknown quantity at this point
Wonder why portforward.com uses ports123 forwarded. Google search did show good amount posting at differrent places. I did check all the ports listing to verify yet from manufacture .... I saw few listed 133 etc so when I saw portforward.com listed figure 123 is needed
  #24
Old January 21st, 2011, 10:21 AM
Senior Member
NETGEAR Addict
If the MFGR requires port:123 then users need to revolt. It would be like restricting port:80, 22, 23, 8080, and the 4-5 other "main" ports that are common.
  #25
Old January 22nd, 2011, 07:22 AM
andrewcall andrewcall is offline
Junior Member
NETGEAR Newbie
andrewcall is on a distinguished road
There are check out the vodafone sure signal forums
  #26
Old January 22nd, 2011, 07:56 AM
jmizoguchi's Avatar
Junior Member
http://forum.vodafone.co.uk/t5/Vodaf...ght/true#M5450
Quote:
212.183.133.178
these are the ports needs to be open
http://forum.vodafone.co.uk/t5/Vodaf...ght/true#M1560
this thread also show same ports I seen... no 123 ports
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
