#101
Old February 5th, 2011, 02:21 PM
Devor's Avatar
Devor Devor is offline
Senior Member
NETGEAR Addict
Devor is on a distinguished road
Default Re: New Firmware Posted: WNDR3700/WNDR37AV Firmware Version 1.0.7.98
Quote:
Originally Posted by Seraphus View Post
That's actually too little information.
You may have missed the irony.
__________________
WNDR3700v1 (v1.0.7.98NA)
System Up Time: 767:16:03:06
How To Check and Change Your Router's Firmware:
http://forum1.netgear.com/showthread.php?t=63234
  #102
Old February 5th, 2011, 02:24 PM
Devor's Avatar
Senior Member
NETGEAR Addict
Quote:
Originally Posted by flaminio View Post
Does anyone have an alternate download location for the new firmware?
See the "Available Firmwares" sticky in this forum.
__________________
  #103
Old February 5th, 2011, 02:25 PM
jlewter jlewter is offline
Senior Member
NETGEAR Addict
jlewter is on a distinguished road
Quote:
Originally Posted by GoNz0 View Post
the trouble is (i found this out as well) TKIP is no longer supported above 54mbs so both 2,4ghz networks will be set to 54mbs if the guest is set to TKIP, I am glad i saved my old router so i can hook up my old PDA that does not support AES
This is a compliance feature..
People aregue that the router doesnt comply to a standard, then they are upset when it does comply to a standard...
GimmeGreenfield.
  #104
Old February 5th, 2011, 02:27 PM
Senior Member
NETGEAR Addict
Quote:
Yea... Happens a lot on global forums...
  #105
Old February 5th, 2011, 03:03 PM
joebonka joebonka is offline
Junior Member
joebonka is on a distinguished road
I just wanted to say that this firmware is working perfectly for me - everything that was broken is now fixed, and everything that was working is still working. Nice one Netgear, thanks for listening to what needed to fixed and then fixing it!
  #106
Old February 5th, 2011, 03:06 PM
Jobster Jobster is offline
Junior Member
NETGEAR Newbie
Jobster is on a distinguished road
ok, just updated both my 3700 v1's to 98, one as AP other as router. just updated, no resets, 30/30/30 watchamacallit, or whatever, set it IPv6 autodetect, and left initial setting as were.
Results: very (!) fast loading web pages, speed both wired (router and AP are hardwired) as well as wireless well up against previous stats.
I'm happy.
  #107
Old February 5th, 2011, 03:36 PM
patrickgerry patrickgerry is offline
Junior Member
NETGEAR User
patrickgerry is on a distinguished road
So far this is the best firmware. No issues whatsoever. Also, no complaints from my son who plays Starcraft 2 and Wow. Great job Netgear!
  #108
Old February 5th, 2011, 05:28 PM
Zainday Zainday is offline
Junior Member
NETGEAR Newbie
Zainday is on a distinguished road
Getting half the write speed to usb...
Seen one other post with this issue....
Went from 15mbs to 8mbs...
Anyone else noticing this?
  #109
Old February 5th, 2011, 10:55 PM
mggtiger mggtiger is offline
Junior Member
NETGEAR Newbie
mggtiger is on a distinguished road
Quote:
Originally Posted by mworley View Post
I just updated and and am hoping it cures a random dropped connection problem. With the previous firmware (1.0.4.68) I had dropped internet connections all the time, maybe once a day to once every couple of days (would affect both wireless and wired). I thought it was occuring when my WAN IP address lease would renew, but I don't think that was it due to never having that problem with my old FVS318. Nonetheless has anyone else had a similar problem of randomly dropped connections? Also, with my FVS318 I could reboot the router from within the GUI, but I don't see that within the WNDR3700. Is it there and I'm overlooking it or is there another way to reboot the router from a browser (or telnet, etc...) without having to hit the power button on the back?
Thanks in advance.
I, too have been using .68 for a long time. All was well until I replaced my Motorola SB5100 cable modem with the latest and greatest SB6120 last fall (Comcast, Chicago area). Then I got the dropped connection problem you mentioned, exactly as you described it. When I reverted to the SB5100, all problems went away and Internet has been rock solid. Just sayin', sometimes it's not the router.
  #110
Old February 6th, 2011, 03:02 AM
grindax grindax is offline
Junior Member
NETGEAR Newbie
grindax is on a distinguished road
Yes, I also noticed that write speed to the USB-attached drive went down significantly. I have an ext3-formatted drive attached and to copy a 700MB file to the drive now takes 90 seconds, which is a rate of slightly below 8MB/s. Previously it would take less than 1 minute.
But other than this issue, everything else is working very well, so overall I think this is the best firmware so far.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
