#21
Old February 26th, 2011, 01:28 PM
inoteb inoteb is offline
Junior Member
NETGEAR Newbie
inoteb is on a distinguished road
Default Re: resume from standby
Hi,
Same problem here since the beginning (all FW since 268 I think).
With or without USB/SD.
DLNA is disabled.
The only way I found is : never put the unit in standby
And
I'll try to get a log
  #22
Old February 27th, 2011, 05:45 AM
Junior Member
NETGEAR Newbie
Log files sent (PM)
  #23
Old March 1st, 2011, 09:13 AM
hawkeye1949 hawkeye1949 is offline
Junior Member
NETGEAR User
hawkeye1949 is on a distinguished road
It happens to me also,with or without USB connected. I never put the unit un standby, and it still happens.
__________________
EVA - NeoTV550 (Wired), HDMI -> Onkyo 7.1 Receiver (TX-SR707)
NETWORK & NAS - ReadyNAS NV+ (4x2.0TB), Cisco Linksys E3000 Gigabit Router, (2) Netgear GS605 Gigabit Switches. APC UPS ES750.
  #24
Old March 5th, 2011, 07:57 AM
PlayIt PlayIt is offline
Senior Member
NETGEAR Newbie
PlayIt is on a distinguished road
Is the toslink (red) light supposed to be on in standby mode?
  #25
Old March 5th, 2011, 08:55 AM
Junior Member
NETGEAR Newbie
Quote:
No, should be orange (red = power off)
Apart from that, the "resume from standy" problem may be solved in the next firmware : perhaps something related to USB being power off when going to standy and powering on USB at the same time as HDMI.
To be continued ...
  #26
Old March 5th, 2011, 09:18 AM
Senior Member
NETGEAR Newbie
I'm talking about the toslink on the back for audio is on. I'm not talking about the light on the front.
  #27
Old March 5th, 2011, 09:52 AM
Junior Member
NETGEAR Newbie
Sorry I read to fast.
I don't know if this is normal but mine is also red in standby
  #28
Old March 6th, 2011, 12:37 AM
Pix Pix is offline
Junior Member
NETGEAR Newbie
Pix is on a distinguished road
First I would like to say that my unit have this resume problem as well. I have a 8GB USB memory as cache in the back of the machine. USB timing issue could very well be the problem. Looking forward to try the next FW.
I would like a new feature that makes a visual indication that the unit actually receives the signal, when pressing powerup button on the remote when the unit is in standby mode. Waking up the unit takes some time and no visual indication at all is frustrating.
  #29
Old March 6th, 2011, 09:12 AM
Blenky Blenky is offline
Junior Member
Advanced NETGEAR User
Blenky is on a distinguished road
I' running the latest Beta and always put the box into standby (orange light) when finished using it. Quite often when turning the unit back on the light goes green but nothing appears on screen. If I turn it back into standby it goes orange as usual. From here turning on changes the light to green but nothing on screen.
Only solution is to pull the power. Does not happen every time but enough to be a pain.
  #30
Old March 6th, 2011, 09:50 AM
dchainey dchainey is offline
Senior Member
NETGEAR Expert
dchainey is on a distinguished road
As I've mentioned earlier in this thread, I've had this problem intermittently with the Neo 550 and the 9150. I usually see it right after the installation of a new FW, but it goes away after a day or two. I have not had it with FW 308, which I thought was meant to cure the problem. However it is very episodic, and may just be waiting to rear it's ugly head again. For the record I have an SD card permanently plugged in, but nothing in the USB ports.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
