#11
Old March 2nd, 2011, 11:41 AM
NatRay's Avatar
NatRay NatRay is offline
Senior Member
Advanced NETGEAR Expert
NatRay is on a distinguished road
Thumbs up Re: WPS light on all the time
Quote:
Originally Posted by quagmire View Post
To disable WPS . . .
Thanks quagmire . . . That works! Proving once again, know one knows it all
__________________
Best regards,
Nat Ray MCSE/MCT since 1997
_______________________
Cox Communications > SB6120 DOCSIS 3.0 > WNDR3700v1 (4), WNDR3400v2 (2), WPN824v2 (2), R7000, RT-N66R *AP(s) via Wired Backbone* > Ooma Telo / D-Link DGS-1024D > NeoTV-550 (3) . . .** HPEnvy800 -PHX **
DD-WRT v24-SP2 (12/14/11) std. Build 18007
Optimize your network: Disable IPv6 . . . Post responsibly . . .
‘Quality trumps Quantity’
  #12
Old March 2nd, 2011, 12:16 PM
RocketJSquirrel RocketJSquirrel is offline
Senior Member
Advanced NETGEAR User
RocketJSquirrel is on a distinguished road
Default Re: WPS light on all the time
To disable WPS, just press the WPS button on the front panel.
You are correct, sir. I thought I had already tried this without success. Seems obvious in hindsight.
  #13
Old March 2nd, 2011, 01:34 PM
Devor's Avatar
Devor Devor is offline
Senior Member
NETGEAR Addict
Devor is on a distinguished road
Thanks quagmire. I hope it survives a power cycle and stays off.
__________________
WNDR3700v1 (v1.0.7.98NA)
Router uptime (d:h:m:s): 1050:08:34:23
How To Check and Change Your Router's Firmware:
http://forum1.netgear.com/showthread.php?t=63234
  #14
Old March 2nd, 2011, 01:52 PM
Sander71 Sander71 is offline
Junior Member
NETGEAR Newbie
Sander71 is on a distinguished road
Another front panel button related issue :
Even if wireless has been configured to only use the 2.4Ghz band, after having switched off the wireless via the front panel (as the environment loving man i am), when you switch it back on, it doesn't care about your configuration and will always switch both 2.4 & 5Ghz bands on. Not environment friendly !
  #15
Old March 2nd, 2011, 02:02 PM
Senior Member
Quote:
Nope. It comes back on.
This router sure is programmed strangely.
  #16
Old March 2nd, 2011, 02:13 PM
Devor's Avatar
Senior Member
NETGEAR Addict
Well that's disappointing. Not sure why it would default on, when it's usefulness is limited to those few times the user needs it and having it running constantly seems wasteful.
__________________
  #17
Old March 2nd, 2011, 03:57 PM
Devor's Avatar
Senior Member
NETGEAR Addict
You don't have to power cycle for it to come back on, I hit the "Apply" button under wireless and it's back on.
__________________
  #18
Old March 2nd, 2011, 04:13 PM
Senior Member
Manual say:
Quote:
While the WPS LED is blinking, you have 2 minutes to enable WPS on the device you are
connecting to. The blinking ceases when one of these two conditions occurs:
• WPS has enabled security between the router and the other device.The router has
generated an SSID, implemented WPA/WPA2 wireless security (including a PSK security
password) on the router and has sent this configuration to the wireless client.
• If you do not establish a connection using WPS during this 2-minute interval, your router
security and SSID (wireless network name) will still be configured for WPA/WPA2
security.
The WPS LED will stop blinking or turn off, depending on how you have them configured.
English not native tongue, kimosabe? Nowhere in manual tell how to configure them to turn off.
But seriously, I doubt the WPS is doing anything when the LED isn't blinking. I think it's just a programming error that it stays on forever if the button has been pushed even once.
  #19
Old March 2nd, 2011, 04:29 PM
curlysir curlysir is offline
Junior Member
NETGEAR Newbie
curlysir is on a distinguished road
When I first got my 3700 the light would not come on after a reset. One of the FW updates changed this and it has stayed that way. Pushing the WPS button will cause it to blink and go off.
This was discussed at some length here when it first occurred.
  #20
Old March 2nd, 2011, 04:43 PM
Junior Member
NETGEAR Newbie
Here are some of the previous discussions, started with 4.68 I think.
http://forum1.netgear.com/showthread...ight=WPS+light
http://forum1.netgear.com/showthread.php?t=52899&page=8
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
