#91
Old May 11th, 2012, 12:18 AM
ossienet ossienet is offline
Junior Member
NETGEAR Newbie
ossienet is on a distinguished road
Default Re: Android HipServ BETA app(Generic) release!!!
Quote:
Originally Posted by Casperuk View Post
have you got more than 1 video player installed?
yes, as I posted earlier:
When I pick a file with ES File Explorer I get three video player options:
ES Viewer, Media Player or Twonky
  #92
Old May 11th, 2012, 05:46 AM
robyb's Avatar
robyb robyb is offline
Moderator
NETGEAR Addict
robyb is on a distinguished road
We just released an update that de-couples Adobe AIR from our app. We implemented that in the last update and it caused errors on some devices in regards to login. Maybe it affected you too in this manner. Give it a try and cross your fingers.
Cheers,
Roby!
  #93
Old May 11th, 2012, 06:20 AM
Casperuk Casperuk is offline
Junior Member
NETGEAR User
Casperuk is on a distinguished road
not sure then. it pops up for me, i know you can set one to default, have you happened to have done that?
  #94
Old May 12th, 2012, 12:11 AM
Junior Member
NETGEAR Newbie
Updated the app from Play Store. No change in behaviour that I can detect.
I don't have a default video player - at least I can't see where one is set.
  #95
Old May 12th, 2012, 10:14 PM
frogger55 frogger55 is offline
Junior Member
NETGEAR Newbie
frogger55 is on a distinguished road
Was wanting to give this another go since the changes, but am having trouble logging in -
Keep getting invalid login or password. I'm certain username and password are good, but can i double check how to enter the Hipsev name?
Is it storaname.mystora.com ??
Any help appreciated.
Cheers,
  #96
Old May 14th, 2012, 07:33 AM
robyb's Avatar
Moderator
NETGEAR Addict
Cheers,
Your Stora name is your HipServ name. When you choose the product it already knows what server to talk to, no need to enter mystora.com .
Cheers,
Roby!
  #97
Old May 15th, 2012, 12:08 PM
Junior Member
NETGEAR Newbie
Quote:
Cheers,
Roby!
Oh, OK it's all good - I swear there was a 3rd input for hipserv name tuther day.
Must have been dreaming. Thanks Roby
  #98
Old May 21st, 2012, 06:32 AM
Junior Member
NETGEAR User
its in applications -> settings , can't check at the moment
  #99
Old May 21st, 2012, 08:17 PM
Junior Member
NETGEAR Newbie
Meh never mind. I worked around the problem by installing yet another video player (MX Player). Now the HipServ app works as expected - when I tap on a video file it gives me 4 player options.
I guess the new install fixed whatever was broken with file associations previously.
Question: Why aren't mkv files recognised as video files though?
  #100
Old June 4th, 2012, 11:25 AM
reavesga reavesga is offline
Junior Member
NETGEAR Newbie
reavesga is on a distinguished road
Need support for .mp4 play back.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
