Thread Tools | Display Modes |
#11
Joe,
Thanks for the feedback. Sadly the stability was only limited. I have now had about 5 disconnects in the span of 2 hours. The connection dies and then comes back again within 15 to 20 seconds. This never happened with the 6 year old Linksys Router!! I have also been watching the signal with inSSIDer and apparently both my signals (2.4Ghz and 5Ghz) drop at the same time or very close to each other, when this happens. I changed the setting to be 54Mps, reconnected all devices. 2 Laptops, 1 Blackberry and 1 Nintendo Wii (streaming netflix). (Since 3 out of 4 connect at 54Mps anyway). Started streaming netflix and within 20 minutes had another disconnect. inSSIDer shows both connections dropped (the Time Graph has a disconnect in the signal). I am all out of ideas... any one have any suggestions on what to try? I am pretty much ready to take this thing back!
#12
ABitTooSpicy,
Do you have your router standing vertically (ie. on the 2 "feet" provided) or lying flat (ie. horizontally)? Just a thought, but I have my 3400 vertical because I do find that it runs a bit on the hot side and this position allows for better heat dissipation. Could it be that your router is overheating and after it cools off a bit it works better???
#13
Great minds think alike. I thought the same thing, as initially I did have it lying flat and it did feel very hot. Now it is vertical for the last day or so, and doesn't seem to have resolved anything.
I ended up calling support and I was told that returning it is my only option as this is a known issue with some of the routers, a firmware update usually fixes it but since I have already done the firmware update and tried all the things listed above, the support person had nothing else for me to try... ![]() I guess back to Best Buy it goes... Last edited by Mars Mug; July 18th, 2011 at 10:39 PM. |
#14
ABitTooSpicy,
It could have sustained sufficent damage already to weaken some internal components. I agree that since you still have that window of time to return it then you should. Good luck!
#15
Hi ABitTooSpicy,
I don't know if you've tried this yet, but if not, try it. 1. Go into your router settings page. 2. Go into the wireless settings section. 3. If you have two networks, it shows the wifi name twice, look for Mode. 4. Change it to "Up to 145Mbps" 5. Do this for both if there's another one. Hopefully this will fix your internet. -Netgearuser38 Last edited by Mars Mug; July 18th, 2011 at 10:38 PM. |
#16
Was a fix found for this issue?
I have a new N600 and the same thing is happening. I can rule wireless out as wired connection also show the same thing. It's not the individual PCs as everything can see the router but the router cannot see the modem. The modem works fine as plugging a pc directly into the modem lets that pc see the internet. |
#17
And your router was working for a period of time before you started getting disconnected from both wired and wireless PCs?
#18
I have a similar problem but different enough that I will list my situation:
Thanks in advance for any assistance/advice. Ruvi |
#19
To begin with, IMHO you really should have started a new thread if you read this. Nevertheless...
Quote:
Quote:
Quote:
If your router has already sustained heat damage unbeknownst to you, there is little that changing the orientation can do for you now. Quote:
#20
Quote:
Quote:
As an experiment, I returned the router to the horizontal position - but it didn't help. I had to reset the router to read your post. And I don't even have to unplug it. I use the switch on the router to power down the router, and then after a few seconds, restart it. Quote:
Hardware Version WNDR3700 Firmware Version V1.0.7.98NA GUI Language Version V1.0.0.64 Quote:
Router signal range hasn't been an issue for me - whether stored vertically or horizontally. When it works, it works well. Quote:
The one other thing that comes to mind is that for some reason it's losing track of the IP assigned by my ISP - and restarting causes the N600 to go back to my cable modem and request the IP. Thank you for your advice and patience. I'll try contacting Netgear and see if they have any suggestions and/or will replace it for me. If I learn anything of significance, I'll add it to this thread. Ruvi |
| Thread Tools | |
| Display Modes | |
