#21
Old November 15th, 2011, 03:45 AM
rsinj rsinj is offline
Senior Member
Advanced NETGEAR Expert
rsinj is on a distinguished road
Default Re: Stora drive compatibility list
cambo - no issue whatsoever using different drives, they can even be very different with one being 7200 RPM and the other 5900 RPM. Different manufactures/models no problem.
__________________
Howard
  #22
Old November 16th, 2011, 02:19 AM
cxlen4 cxlen4 is offline
Junior Member
NETGEAR Newbie
cxlen4 is on a distinguished road
Samsung hd103sj - 1 tb
  #23
Old December 4th, 2011, 06:00 AM
SpudNuts SpudNuts is offline
Junior Member
NETGEAR Newbie
SpudNuts is on a distinguished road
Seagate - ST3000DM001-9YN1 - 3TB
  #24
Old December 4th, 2011, 10:20 AM
Yoji Yoji is offline
Junior Member
NETGEAR Newbie
Yoji is on a distinguished road
Care in the above 3TB "compatible" drives. They dont work as standard Spud had to
Quote:
I had to back door the device and make a few changes to the configuration for it to work. I had to manually create the raid and redo the partitions on the Stora
So dont just chuck in 3TB drives and expect it to work.
http://forum1.netgear.com/showthread...805#post381805
Cheers
  #25
Old December 5th, 2011, 10:12 AM
Junior Member
NETGEAR Newbie
Cheers
True. Sorry, I guess I should have mentioned that
  #26
Old December 9th, 2011, 03:36 AM
Galin Galin is offline
Junior Member
Galin is on a distinguished road
Working:
1TB Wester Digital WD10EURS
Not working:
200GB Maxtor 6L200S0
200GB Maxtor 6B200M0
  #27
Old January 17th, 2012, 06:44 AM
omichaels omichaels is offline
Junior Member
NETGEAR Newbie
omichaels is on a distinguished road
Using two Hitachi HDS723020BLA642 2TB drives with no problems. (not listed above.)
  #28
Old January 31st, 2012, 01:36 PM
eiuep eiuep is offline
Junior Member
eiuep is on a distinguished road
Hi,
I just bought MS2000 and I am selecting the drives.
I would have 2 x 2Tb drives working in RAID1.
I found ST2000DL003 inexpensive but it is not officially supported.
Anyone have tested this disk in raid 1?
I know WD20EARX is fully supported but I found it more expensive.
cheers
  #29
Old January 31st, 2012, 02:43 PM
Senior Member
The Seagate drive is on our list - see post #15.
__________________
Howard
  #30
Old January 31st, 2012, 09:54 PM
Junior Member
Thanks for your reply.
I have read the post before writing.
Since you were asking to report for any driver not listed I was not sure if the drive was really tested in raid 1.
Please are you able to confirm that it is fully supported so I will be more confident to buy it?
cheers
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
