#21
Quote:
Steam can open MASSIVE # of connections & some router firmware may be set too SENSITIVE and perceive it as an attack by dropping those connections and exhausting the "MEASLY" 4096 connections present. You may consider a separate free x86 router or 3rd party firmware or a router which has more firewall controls, settable # of connections, etc... smallnetbuilder has some good info on this. I've used m0n0wall & pfSense w/ wndr3700v1 as an AP w/ great success! |
#22
I upgraded to 1.0.16.98 and I started the "schedule" feature in "Advanced Wireless Settings, between midnight and 5 am. The router turned off the signal at midnight but didn't restarted at 5 am. I had to enter the settings and restart the wireless manually.
#23
Quote:
#24
Quote:
#25
Quote:
320GB model. I have it attached 24/7 and changed the workgroup to match my own and have only the internal network connection enabled. No specific network folder was created but the share appears nonetheless as 'Readyshare' in my network. I have it formatted as ext3. Quite pleased with it! |
#26
I did disable the traffic meter using the telnet batch file I downloaded from a user here also...
#27
Quote:
#28
In order to use AP mode is advisable to use WAN port? (With .14 it was necessary to avoid bugs)
Upgraded yesterday only to access to webgui it needed 3 reset. Using AP mode i founded WNDR3700 after 12Hrs with Webgui freezed and WiFi not working (SSID listed but cannot connect). Power cycle and now is working... I fear that this is a buggy fw release! |
#29
In the release notes says:
Support "AP mode" and "Auto IP" in AP mode. Has anyone found any documentation for this feature? |
#30
Using WAN port AP Mode doesnt' work
| Thread Tools | |
| Display Modes | |
