#11
I think its all fixed. I did a 30-30-30 reset and now the router is behaving normal again.
#12
Good for you... though it would have been nice to know what was causing this strange behavior.
#13
Sorry to bump a year old thread, but I'm having the exact same issue... however a hard reset did not fix it,
I can confirm that this is a router software issue because tomato doesn't have the same issues... Why is my wireless activity acting like a dumb hub than a semi-smart switch? |
#14
if you read through... suggest to contact support.
there is nothing you can do with the way firmware behaves
__________________
VPN Case Study (www.vpncasestudy.com) Our Second To None VPN Related Setup Case Study "One Stop Solution To Your Netgear VPN Connectivity" *Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support] Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin" "Wireless Tips" Forum Policy June Mizoguchi-i....@vpncasestudy.com |
| Thread Tools | |
| Display Modes | |
