#51
Old August 24th, 2011, 11:51 AM
regulus6633 regulus6633 is offline
Junior Member
NETGEAR Newbie
regulus6633 is on a distinguished road
Default Re: Mac OS 10.7 Lion and Time Machine
Quote:
Originally Posted by ajonesnv
Will the mac address matte if I am using my WiFi?
I'm not sure to be honest. I believe you should use the ethernet mac address in either situation. Try that. If it doesn't work then use the mac address of the wifi card which you can also get from the Network preference pane.
  #52
Old August 24th, 2011, 11:57 AM
sillyname sillyname is offline
Senior Member
Advanced NETGEAR Expert
sillyname is on a distinguished road
From my understanding, even if the network backups will be done using a different port (e.g. AirPort: usually “en1″) the system will use the address of en0 as part of the system identifier.
  #53
Old August 24th, 2011, 12:13 PM
ajonesnv ajonesnv is offline
Junior Member
NETGEAR Newbie
ajonesnv is on a distinguished road
regulus6633:
Ignore that last post. I did all the steps, but the backup failed. Every thing seemed to work well, at least I got no errors while in the terminal. Im wondering about step 7. I matched my name the way you said, but should there be some thing after Volume (specific to my computer) on the code line "sudo tmutil setdestination -p /Volumes/Backup\ of\ MacBook\ Pro"
  #54
Old August 24th, 2011, 12:16 PM
Junior Member
NETGEAR Newbie
Quote:
Turns out they are the same, so that is one hurdle down.
  #55
Old August 24th, 2011, 12:18 PM
Junior Member
NETGEAR Newbie
Could it be an issue as to where the backup is mounted?
  #56
Old August 24th, 2011, 12:44 PM
Junior Member
NETGEAR Newbie
OK actually I think it is step #6. How do I mount the sparsebundle to my computers?
  #57
Old August 24th, 2011, 01:06 PM
Senior Member
Quote:
$ open YOUR_SPARSEBUNDLE_NAME.sparsebundle
Or, if I'm reading it properly you could open TM in System Preferences and selected the image you just made (Select Disk). Then set the type of backup when your there (Options).
The method he's using is after making a sparsebundle and sizing is to mount (open), then copy your MBP contents.
  #58
Old August 24th, 2011, 01:17 PM
Junior Member
NETGEAR Newbie
Well, maybe I have a deeper issue. The image I made dosent show up in the TM preferences. AHHHHHHHHH, I wish I understood this stuff better. thanks for all the info, it would be great if an update was made for us idiots.
  #59
Old August 24th, 2011, 01:28 PM
Junior Member
NETGEAR Newbie
OK, Im blowing this place up, but how do you "$ open"? I know, I know...Im a newby idiot that needs flamed!!
  #60
Old August 24th, 2011, 01:31 PM
Senior Member
Step 5 would be an important step to tell TM to look at a non HSF drive.
defaults write com.apple.systempreferences TMShowUnsupportedNetworkVolumes 1
I understand your frustration, we can only hope they will complete this update soon.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
