#21
Old February 3rd, 2012, 10:54 AM
enrydgl enrydgl is offline
Junior Member
NETGEAR User
enrydgl is on a distinguished road
Default Re: Movie Wall Misbehaving
@8bit
Hi 8bit,
a boy with popcorn a-300, send me this solution for your BD problem with A-300 mediaplayer.
You must used DVDFab 8.1.3.8 to ripping BD1:1 (no AnyDVD). In Options (green flag near "?") you must setting this checkbox :
- DVD/Bluray --> Protection --> Bluray :
Remove AACS, Remove BD+ and Remove BD+ firmware
On Popcorn configuration you must setting "on" in "full navigation".
Can you test for me this ripping solution with A-300? This solution for me doesn't return a correct BD execution. The BD with Java Menu start immediately with main movie without menu.
Bye.
  #22
Old February 6th, 2012, 12:40 PM
8bit 8bit is offline
Junior Member
NETGEAR Newbie
8bit is on a distinguished road
Quote:
Originally Posted by enrydgl View Post
@8bit
Hi 8bit,
Bye.
I'd like to help you but I don't use DVDFab products. They seem to nickel and dime you and with the research I've done; AnyDVD does the best job at ripping 1:1 BD's. I paid for the lifetime sub for AnyDVD as well and I don't plan on buying a replacment.
I tried leaving & removing BD LIve support within AnyDVD without success. I have a pretty good felling that the tool to rip the BD's is not the problem but something to do with the a-300. Those titles that wouldn't play on my a-300 played without a hitch on my 550.
The A-300, I had it to prompt me for the type of menu (full or simply). Nothing worked.
8bit
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
