#11
Old August 26th, 2011, 06:46 AM
r_broberg r_broberg is offline
Junior Member
NETGEAR Newbie
r_broberg is on a distinguished road
Default Re: need help with fvs338=>iphone/4 vpn
Quote:
Originally Posted by MrWichtig View Post
Hi,
i also have the FVS338 Router and have many days spent for Troubleshooting the problem Iphone 4 (OS 4.3) connected with IPsec to the FVS338 but no Routing to any local ip adress is possible. But now i've finally solved the problem, but i don't know why now it works!
First, the "How To" from vpncaesstudy.com helped me for the basic Configuration. (Thx a lot, this explains everything very well !)
my local IP Range is 192.168.1.0/ 24 (Router IP 192.168.1.253)
i always have use a 10.10.10.1 - 10.10.10.5 Pool (first pool) in the "Mode Config" Settings.....with this configuration it is possible to connect with Ipsec, but not a routing to the local ip range.
now i have config a 172.16.0.1- 172.16.0.5 pool (first pool) in the "Mode Config" Settings.....and "ttaaattaaa" all local ip adresses are pingable and routing to all clients are also possible!
so far so good, except this i'm intersted, why the client pool 10.10.10.1-10.0.0.5 in Mode Config settings is not routable for ipsec vpn???
This IP Adresses, Range, Subnet (or anything from 10.x.x.x.x) i don't have anywhere in Use!
can someone explain that to me?
If No, it's also OK for me....VPN with Iphone WORKS now!
Hmm - it still doesn't work for me, even after I change the 'mode config' first pool to 172.16.0.1=>172.16.0.5, as you did. Same behavior - the vpn connects up just fine, but I cannot get to any devices on the network behind the netgear router. Can you verify that the *only* thing you changed was that 'mode config' subnet?
  #12
Old August 26th, 2011, 08:59 AM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Senior Member
NETGEAR Fanatic
jmizoguchi is on a distinguished road
I believe so... there isn't much for setting in IPsec to play with
__________________
VPN Case Study (www.vpncasestudy.com)
Our Second To None VPN Related Setup Case Study
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin"
"Wireless Tips"
Forum Policy
June Mizoguchi-i....@vpncasestudy.com
  #13
Old August 26th, 2011, 01:47 PM
MrWichtig MrWichtig is offline
Junior Member
NETGEAR Newbie
MrWichtig is on a distinguished road
Yes, i only change the clientrange for "mode config" otherway the "how to" from vpncasestudy.
My 3G provider is t-mobile and there are now no problems.
  #14
Old August 28th, 2011, 01:02 PM
JonW JonW is offline
Senior Member
Advanced NETGEAR User
JonW is on a distinguished road
Congrats on getting it working.
I suppose it's possible the 10.10.x.x range was being used by the router you were connecting to and that was causing problems.
  #15
Old August 28th, 2011, 01:48 PM
Junior Member
NETGEAR Newbie
Hi,
Which router you mean? My fvs338?
Or the 3G provider or my internet Provider (Wan Interface FVS338) ?
Locally is IP Range 10.x.x.x not in use.
  #16
Old August 28th, 2011, 03:36 PM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
means REMOTE end.
__________________
"Wireless Tips"
Forum Policy
  #17
Old August 28th, 2011, 11:35 PM
Junior Member
NETGEAR Newbie
My remote end (wan interface) is 91.x.x.x .
Only thing is in my dial up configuration "ISP Type" i have a 10.0.x.x ip Adress filled in under "my ip adress" and "server ip adress" but not a 10.10.x.x ip adress
  #18
Old August 29th, 2011, 04:16 AM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
some to do with 10.x subnet. I'm sure LAN side you were using were class C 255.255.255.0 subnet
__________________
"Wireless Tips"
Forum Policy
  #19
Old August 29th, 2011, 10:24 AM
Senior Member
Hi,
Yeah, I was referring to the remote side that your IPhone is connecting to: the 3G or Wifi network you're accessing. I would think if 10.x.x.x was defined by the VPN, and also used by the router itself - that it would route the traffic over the VPN; but with so many different routers out there and so many different versions of firmware and configs... who knows?
  #20
Old August 29th, 2011, 01:06 PM
Junior Member
NETGEAR Newbie
Yes, my lan subnet is class C
......and i also can live with a 172.x.x.x working client vpn pool
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
