#1
Old September 6th, 2011, 12:05 PM
whitefeather whitefeather is offline
Junior Member
NETGEAR Newbie
whitefeather is on a distinguished road
Default How to Turn off MAC Filtering
I have a Netgear WNR2000v2 Router, I have been having problems connecting to the router from my wireless printer. Spoke to HP's Tech Support today and after several checks he needs to Turn Off the MAC Filtering on the Router so that he can do further tests tomorrow morning.
I have the Routers username and password but when I go into the Router management I don't know where to look and what to change.
Can someone help me please
  #2
Old September 6th, 2011, 01:06 PM
bastialex0825 bastialex0825 is offline
Junior Member
NETGEAR Newbie
bastialex0825 is on a distinguished road
Default Re: How to Turn off MAC Filtering
Inside router management, go to wireless settings under advance and click set up access list.
  #3
Old September 6th, 2011, 02:29 PM
Junior Member
NETGEAR Newbie
I have gone to Wireless settings and there is No advanced option there.. this is a copy of what I get on Wireless settings
Wireless Network
Name (SSID):
Region:
Channel:
Mode:
Security Options
None
WEP
WPA-PSK [TKIP]
WPA2-PSK [AES]
WPA-PSK [TKIP] + WPA2-PSK [AES]
Security Options (WPA-PSK)
Passphrase: (8-63 characters or 64 hex digits)
  #4
Old September 6th, 2011, 02:34 PM
Junior Member
NETGEAR Newbie
I have also checked further down the list and found this under Advanced Wireless settings.
but there is not a lot of bits on here
Wireless Card Access List
Turn Access Control On
Device Name MAC Address
  #5
Old September 6th, 2011, 02:53 PM
Junior Member
NETGEAR Newbie
You are refering to the wireless settings under "SETUP". there is another wireless settings option on the menu on the left of the router configuration page under "ADVANCED"
Quote:
Wireless Network
Name (SSID):
Region:
Channel:
Mode:
Security Options
None
WEP
WPA-PSK [TKIP]
WPA2-PSK [AES]
  #6
Old September 6th, 2011, 03:19 PM
Junior Member
NETGEAR Newbie
Available Wireless Cards
Norma-TOSH
BLACKBERRY-73DD
keefyboy-msi
Wireless Card Entry
Device Name:
MAC Address:
This what I got up when I went into advanced> Wireless settings> Wireless Card Access List>Add
and it shows me the above Wireless Card Access List
Please don't think I am thick, I am not used to playing around with the routers settings....
  #7
Old September 6th, 2011, 04:29 PM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Senior Member
NETGEAR Fanatic
jmizoguchi is on a distinguished road
mac filtering is OFF at default so unless you enable it it is NOT using.
under router interface, check ADVANCED >wireless setting for access list (same thing as mac filtering)
you are in the right place... TURN IT OFF
__________________
VPN Case Study (www.vpncasestudy.com)
Our Second To None VPN Related Setup Case Study
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin"
"Wireless Tips"
Forum Policy
June Mizoguchi-i....@vpncasestudy.com
  #8
Old September 7th, 2011, 12:06 AM
Junior Member
NETGEAR Newbie
Right I understand now, and the box is not checked so it is off then. Many thanks, sorry to seem to be a bit slow on it, but i put it down to my age...
But all sorted now, thanks again for your help.
Keith
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
