#21
should able to save way with other extender that do work.. s
__________________
VPN Case Study (www.vpncasestudy.com) Our Second To None VPN Related Setup Case Study "One Stop Solution To Your Netgear VPN Connectivity" *Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support] Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin" "Wireless Tips" Forum Policy June Mizoguchi-i....@vpncasestudy.com |
#22
what? I can't understand you
#23
Sorry. Phone did some weired thing
If one extender works fine then it should the same on 2nd extender which both extender ate connected to main wireless router
__________________
#24
I found something very weird
I have have to wait for 10 minutes before to connect itself when I switched between units why does do that |
#25
strange but can you still ping your router when you are connected to extender?
__________________
#26
I found something else.
if I want to connect between unit. I can't do it less I have to turn the unit off\on it is ok but if I want to connect to other unit, I have to do off\on |
#27
Interesting .......
__________________
#28
how to find pin code of units?
I would like to use pin code to setup. http://www.draytek.com/user/SupportA...ail.php?ID=125 |
#29
Pin is on router side to provides you so that extender can use it
__________________
#30
I found the pin code
what is next? Do u know? |
| Thread Tools | |
| Display Modes | |
