#31
Old September 28th, 2011, 09:43 PM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Senior Member
NETGEAR Fanatic
jmizoguchi is on a distinguished road
Default Re: how to setup UNIVERSAL WIFI RANGE EXTENDER
Just setup extender to use pin.
Installation guide/manual should tell you the steps
__________________
VPN Case Study (www.vpncasestudy.com)
Our Second To None VPN Related Setup Case Study
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin"
"Wireless Tips"
Forum Policy
June Mizoguchi-i....@vpncasestudy.com
  #32
Old September 28th, 2011, 10:28 PM
carlo67 carlo67 is offline
Junior Member
NETGEAR Newbie
carlo67 is on a distinguished road
guide/manual should tell me the steps nothing loll
I worked it by myself
  #33
Old September 29th, 2011, 04:47 AM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
good for you...
__________________
"Wireless Tips"
Forum Policy
  #34
Old October 13th, 2011, 07:36 PM
Junior Member
NETGEAR Newbie
can you tell me how to use the WPS please
step-by-step please
  #35
Old October 13th, 2011, 07:55 PM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
Quote:
step-by-step please
refer to manual or guides from support.netgear.com
usually shows WPS setup and encryption setup.
__________________
"Wireless Tips"
Forum Policy
  #36
Old April 22nd, 2013, 06:59 PM
TSally TSally is offline
Junior Member
TSally is on a distinguished road
I try to connect devices to the range extender AFTER the setup process and it won't let me. The password is correct, I've reset the unit multiple times in order to verify that it's correct, but it won't let me connect any further devices.
Thanks,
Tim
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
