#21
Quote:
"How about the ability to differentiate between 2.4Ghz and 5Ghz connections in the "Attached Devices" pane (which differentiates between Wired and Wireless)." |
#22
Quote:
DNS Servers . . . . . . . . . . . : 192.168.1.1 C:\Users\me>nslookup google.com Server: UnKnown Address: 192.168.1.1 DNS request timed out. timeout was 2 seconds. DNS request timed out. timeout was 2 seconds. Non-authoritative answer: Name: google.com Addresses: 173.194.33.0 173.194.33.1 173.194.33.2 173.194.33.3 173.194.33.4 173.194.33.5 173.194.33.6 173.194.33.7 173.194.33.8 173.194.33.9 173.194.33.14 I take it you're looking to bypass the local DNS entirely? |
#23
Absolutly need IPV6 RD (rapid deployment) support. As many others, my ISP is going this way. Linksys and DLink do support it.
#24
Can you explain how it doesn't do this? I see the option to disable the router PIN. Should it do something else?
#25
How about a way to "override" the Live Parental Controls from something other than a Windows or Mac computer?
Shouldn't be too hard to set up a web-based login page where someone could "identify" themselves as a valid user so they are subject to less strict Parental Controls. Or iOS/Android apps. |
#26
Another one: how about support for ExFAT for files >4GB without having to use NTFS (which is read-only anyway)?
#27
Can't believe this isn't in here, but....MORE than 20 port forwarding rules...
#28
Linux software to access ReadyShare printer (does anyone know if this is possible)?
#29
Agreed, way too few
#30
What number do you consider would be enough, and what other home grade or small business grade router do you know of that exceeds 20 rules by a significant margin?
Sethfeinberg also posted this thread http://forum1.netgear.com/showthread.php?t=77134
__________________
I don't work for Netgear. My name is Andy. |
| Thread Tools | |
| Display Modes | |
