#11
Old November 9th, 2011, 12:29 AM
bilbonvidia bilbonvidia is offline
Junior Member
NETGEAR Newbie
bilbonvidia is on a distinguished road
Default Re: Who uses opendns parental controls on DGND3700
Some time later my issue has now made it to the engineering department. I await a response.
Again it would be nice if other people could test it so I had something more to go back to Netgear with.
  #12
Old November 9th, 2011, 04:21 AM
theTechman05 theTechman05 is offline
Senior Member
NETGEAR Expert
theTechman05 is on a distinguished road
Unfortunately the ready dns site I went to charged money to use it and I have no reason right now to use its features. Always thought there was free one too.
  #13
Old November 9th, 2011, 04:33 AM
Senior Member
NETGEAR Expert
Lightbulb Re: Who uses opendns parental controls on DGND3700
Crud found a glitch the darn router shows the wrong link for the service. I assume It should point to opendns.com and not dyndns.com
  #14
Old November 9th, 2011, 06:33 AM
Junior Member
NETGEAR Newbie
If you are trying to use the opendns live parental controls you dont touch the dyndns section although admittedly it would be nice to have an opendns updater there as an option.
To use the parental controls create a free opendns account here:
https://store.opendns.com/get/home-free
You then download the live parental control facility:
http://countries.netgear.com/lpc
and run it entering the account information you just set up and configure what you want to be blocked. The you should be good to go and inappropriate pages should be blocked. Takes 5 minutes.
However when I reboot pages stop being blocked until I re-enage parental controls with the utility again.
  #15
Old December 29th, 2011, 05:34 PM
cnewtonne cnewtonne is offline
Junior Member
NETGEAR Newbie
cnewtonne is on a distinguished road
I'm running to same issue using dgn2200. Lpc works, but after shutting down pc or rebooting router, it stops working on any device and Internet is wide open. I have to go back to lpc mgmt tool and do disable/enable. It then works.
I called ng support and they gave up on me and offered no solution.
I could've used open dns home protection offering away from netgear, but I did not like the updater utility because it needs to be running 24x7. Lpc,somehow, they take care of the dynamic ip problem.
As of now, I do not really trust Lpc offering and may return the router. I may have to rely on k9 protection for now. This is sad.
Did you resolve your issue?
  #16
Old December 30th, 2011, 08:01 AM
Junior Member
NETGEAR Newbie
No.
I sent my config files etc to Netgear Support again today. The issue is still with engineering.
  #17
Old January 1st, 2012, 12:48 PM
richard1985 richard1985 is offline
Junior Member
richard1985 is on a distinguished road
I am also having the exact same issue with the DGN2200. I spoke with their technical support department numerous times to try to resolve the case but got nowhere. One person said it was a problem with the hardware and for me to check back in 6 weeks time. When I called back they said they would pass it on to their level 2/3 support, and that they would call back, but I've not heard anything back. That was back in July 2011. Its now 6 months later and the problem has still yet to be resolved!
I believe the problem lies with the router failing to notify OpenDNS of a change to the dynamic IP address which occurs when the router reconnects. This was the main reason for me purchasing the router as it avoids having to run an update program client side.
On the LPC FAQ page it says:
Q: What if I have a dynamic IP address? Does different types of Internet services (DSL, Cable, etc) this affect Live Parental Controls powered by OpenDNS?
A: The router can handle different types of Broadband Internet connections including DSL, Cable, it Changes to your IP address are automatically handled by your router and will not affect your filtering settings.
This looks like false advertisement to me! I plan on writing a formal complaint about this, and I would urge everyone else experiencing the same problem to do the same. The LPC is not fit for purpose or functioning as advertised. The more complaints they receive the more likely it will speed things up so the issue can be resolved and the LPC system actually be functioning as advertised.
  #18
Old January 8th, 2012, 08:24 AM
talktome talktome is offline
Junior Member
talktome is on a distinguished road
I'm glad I found this thread as I've got the same problem with my DGN2200. I've spent a couple of days trying to figure this one out and was just about to contact the support team.
I must say I'm really dissapointed! I Purchased this router to replace my last fully functioning Netgear router just because I wanted parental control but it looks like I've wasted my money.
If Netgear had made indications that a fix was in the pipeline I would hold onto it but from what I've heard on this board about 6 month waits and still no solution..Looks like I'm going to seriously consider returning this to the shop I got it from for a refund.
Just wondering does anyone know if there is either a Netgear or any other make of router that has WORKING parental controls?
Thanks.
  #19
Old February 13th, 2012, 10:49 AM
Junior Member
NETGEAR Newbie
Maybe they've been reading the forums!
Just received V1.0.0.19_1.0.19_Test3 and it looks to have fixed Live Parental Controls on the DGND3700.
TFFT.
Fingers crossed, will report back tomorrow.
Hopefully the fix can be ported to other devices with the same issue.
  #20
Old February 19th, 2012, 12:10 PM
dereksurfs dereksurfs is offline
Junior Member
NETGEAR Newbie
dereksurfs is on a distinguished road
Geesh, I'm glad I saw this thread. LPC is the only reason I am considering Netgear DGND3700 over ASUS or Cisco. Then I find out here that this feature is not working, problematic or just being fixed in some beta release after being out there for how long? Sorry, but this just sounds ridiculous. What is up with Netgear? They have had a serious problem in production for over 6 months and only now are starting to address it? So everyone's fingers are crossed?
On top of all this I am reading that r3 is an inferior product to r2 which is inferior to r1. Is anyone else noticing a trend here?
Derek
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
