#11
Old October 31st, 2011, 08:29 AM
Simon0 Simon0 is offline
Senior Member
NETGEAR Expert
Simon0 is on a distinguished road
Default Re: Experience with 1.0.16.98 for V1?
Quote:
Originally Posted by therat View Post
Once a WNDR3700 v1 has been flashed with gargoyle firmware, is it possible to go back to the netgear firmware?
3rd party firmware will often allow you to flash anything to the router and firmware header protection is often disabled. So tftp may not be needed. Flash failure via webui is oftentimes caused by browser cache issues.
  #12
Old October 31st, 2011, 10:43 AM
NightOwl326 NightOwl326 is offline
Member
NETGEAR User
NightOwl326 is on a distinguished road
Quote:
Originally Posted by Simon0 View Post
The Gargoyle firmware does seem to have EXCELLENT Atheros support.
Does Gargoyle do readyshare of hard drive with current firmware?
Does it do printer sharing?
  #13
Old October 31st, 2011, 12:05 PM
DodgeDeBoulet DodgeDeBoulet is offline
Member
NETGEAR User
DodgeDeBoulet is on a distinguished road
While I know discussion of 3rd party firmwares for Netgear products has been frowned upon in this forum in the past, I'm extremely curious to hear about any experiences from those that have used Arokh's OpenWRT builds as well as Gargoyle. It appears as though the latter has solved some performance issues seen with Arokh's, but I assume all driver updates had been incorporated into OpenWRT trunk so they would be available in his builds as well.
  #14
Old October 31st, 2011, 12:09 PM
Mars Mug's Avatar
Mars Mug Mars Mug is offline
Moderator
NETGEAR Fanatic
Mars Mug is on a distinguished road
It’s not frowned upon, but these forums cannot develop into support forums for third part firmware. For help and support with third party firmware people need to go to the relevant site, but general discussion OK. Except this discussion is taking this thread off topic.
__________________
I don't work for Netgear.
My name is Andy.
  #15
Old October 31st, 2011, 09:57 PM
Senior Member
NETGEAR Expert
Those are simply packages you can add.
  #16
Old November 2nd, 2011, 04:53 PM
MiloWilson MiloWilson is offline
Junior Member
NETGEAR Newbie
MiloWilson is on a distinguished road
A noob question. You have installed a different firmware other than Netgear firmware to the router?!? I didn't know that was possible. How do you accomplish that? Are there any different loading directions? Can you go back if there are problems?
  #17
Old November 2nd, 2011, 05:07 PM
Senior Member
NETGEAR Expert
Quote:
1. Yes.
2. webgui or tftp.
3. No.
4. Yes.
  #18
Old November 3rd, 2011, 01:13 PM
nToxik nToxik is offline
Junior Member
NETGEAR Newbie
nToxik is on a distinguished road
Default Re: Gargoyle - (Split from Experience with 1.0.16.98 for V1?)
Considering how broken Netgear firmware is at the moment, is there any cons to use Gargoyle? Is there a list of things that are still being worked on or does everything work? How is the speed compared to netgear firmware?
I'm sure I am wrong here but I thought I read somewhere on these boards that Netgear firmware was optimized for the hardware and any other 3rd-party firmware naturally ran slower than Netgear firmware?
  #19
Old November 3rd, 2011, 01:48 PM
Tank_Killer's Avatar
Tank_Killer Tank_Killer is offline
Member
NETGEAR User
Tank_Killer is on a distinguished road
well gargoyle doesnt have the "and everything but the kitchen sink" approach. You will not find a DLNA server (not that the verion in dlinks is super great) ect...
The only feature that I miss is port triggering
  #20
Old November 3rd, 2011, 06:29 PM
KevTech KevTech is offline
Senior Member
NETGEAR Expert
KevTech is on a distinguished road
I would use Openwrt Backfire before I would use Gargoyle as there is a lot more packages you can install.
Openwrt just released RC6 version of Backfire.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
