#21
Old December 5th, 2012, 01:08 PM
mailiang mailiang is offline
Junior Member
NETGEAR Newbie
mailiang is on a distinguished road
Lightbulb Fixing WPS blue light dome blinking on WNDR3400 V2 series
Quote:
Originally Posted by swanlee View Post
I just put duck tape over the light. Seems that it blinks when some device is trying to connect to wps it stopped when I turned off SSID boradcast but some devices are annoying with SSID turned off so duck tape it was. Sad that you simply can't turn off that big blue light it is very annoying.
To disable the WPS when this issue occurs, disable the SSID. Then reboot your computer. You will now have to manually input your id and password to access your network. Open your browser and router utility (Netgear Genie) and enable the SSID again. Your WPS willl remain off unless you turn it back on using the WPS wizard set up utility. You can now push on the router's WPS button and turn the light on or off.
Ian
  #22
Old December 15th, 2012, 07:23 AM
DarrylGF DarrylGF is offline
Junior Member
DarrylGF is on a distinguished road
Smile Re: WPS blue light dome blinks on WNDR3400
Must be why I can find a lot of these 3400 routers in Goodwill stores. I just bought one for $7 and got it going right now. Saving my old Belkin in case this thing starts acting up. The light does not bother me as the router is across the room and it makes a good night light for getting up to go to the bathroom. Just another energy consumer. Reminds me of the old K Mart "blue light" special.
  #23
Old December 15th, 2012, 11:00 AM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Junior Member
jmizoguchi is an unknown quantity at this point
Default Re: WPS blue light dome blinks on WNDR3400
Quote:
no double post
keep to your own thread
http://forum1.netgear.com/showthread.php?t=82194
  #24
Old December 26th, 2012, 09:01 PM
visaya visaya is offline
Junior Member
visaya is on a distinguished road
I had my WNDR 3400 dual band router now for 1.5 years and I was able to disable the blue dome light but after I did a reset, the router dome blue light stays on after pressing a few seconds. Any solutions to this form the Netgear community?
  #25
Old December 27th, 2012, 04:37 AM
Joe_ Joe_ is offline
Senior Member
NETGEAR Addict
Joe_ is on a distinguished road
Quote:
Originally Posted by visaya View Post
...but after I did a reset...
What version of the WNDR3400 do you have?
Are you sure you reset only and didn't upgrade the firmware?
I have the WNDR3400v1 running Firmware Version V1.0.0.38_16.0.48
GUI Language Version V1.0.0.38_2.1.9.1 and I have no problem turning off the dome light. I don't see why you can't if you have the same firmware.
  #26
Old July 12th, 2013, 09:57 AM
lbfodemo lbfodemo is offline
Junior Member
NETGEAR Newbie
lbfodemo is on a distinguished road
WNDR3400 V3 hardware no longer has blue dome that lights up?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
