Thread Tools | Display Modes |
#11
Quote:
I can ping the router regadrless of having a Static or DHCP assigned address. |
#12
Quote:
what is the IP on extender and PC's IP
__________________
VPN Case Study (www.vpncasestudy.com) Our Second To None VPN Related Setup Case Study "One Stop Solution To Your Netgear VPN Connectivity" *Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support] Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin" "Wireless Tips" Forum Policy June Mizoguchi-i....@vpncasestudy.com |
#13
192.x.x.2 & 192.x.x.10
#14
there is useless to hide private ip...
![]() 2 as extender and 10 as PC ? 10 was static IP that you chosen for the PC correct?
__________________
#15
I was able to figure out that the issue was/is. There is what appears to be a bug in the latest firmware. It manifest itself one or two ways.
1. IF you are using the ACL feature of a Netgear router the extender will not be able to assign IP address to the devices that connect to it. ( I beleive the reason is it isn't capable of passing on its MAC address to the router properly) You must turn ACL off for it to work. 2. IF you are using DHCP on your router AND address reservation AND you only have the exact number of IP address that you need being assigned out then the extender will not be able to assigne out the predefined address reservation you've set. You must expand your DHCP pool beyond the exact number of oredefined IP address and it will select from them. (And again in this case, I beleive the reason is it isn't capable of passing on its MAC address to the router properly) Take aways... Turn off ACL and expand your DHCP pool. Netgear Tech Supp was no help this..the simply wanted to follow their script.... :-( |
#16
BTW ...does anyone know how to file a defect with these guys so this can get addressed in a future firmware update?
#17
Use my.netgear.com
__________________
| Thread Tools | |
| Display Modes | |
