#11
Old April 30th, 2012, 12:13 PM
Erikup15 Erikup15 is offline
Junior Member
NETGEAR Newbie
Erikup15 is on a distinguished road
Default Re: Connectivity/Video Issues
Okay....tried again as recommended :-)
Download Speed: 1.59 Mbps
Upload Speed: .43 Mbps
  #12
Old May 12th, 2012, 05:04 AM
Junior Member
NETGEAR Newbie
Is it possible that my problem is more to do with a old/cruddy dsl modem (provided by ATT at the time we got DSL five years ago)?
  #13
Old May 12th, 2012, 07:37 AM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Senior Member
NETGEAR Fanatic
jmizoguchi is on a distinguished road
did you test the speed directly with the ATT dsl modem and pc?
__________________
VPN Case Study (www.vpncasestudy.com)
Our Second To None VPN Related Setup Case Study
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin"
"Wireless Tips"
Forum Policy
June Mizoguchi-i....@vpncasestudy.com
  #14
Old May 26th, 2012, 11:40 AM
Junior Member
NETGEAR Newbie
I did--the speeds came back even lower (both below 1mbps). I contacted ATT and they said that it "appears" there might be something wrong with my DSL line. I'm waiting for Advanced Tech Support to run tests and call me about it.
However--because I'm impatient, I dug out our old Netgear router (WGT624) and plugged it in. ZERO problems streaming a video from YouTube. I ran a speedtest on it and got download speeds of 2.49mbps and .42 upload speeds.
So, now I'm not sure what the issue is. I suppose it could be a faulty DSL line or it could be my router causing the issue. I just can't imagine how a newer router would in fact be worse at handling streaming videos.
With all the confusion, I'm hesitant about what to do next.
  #15
Old May 26th, 2012, 11:56 AM
Junior Member
NETGEAR Newbie
I did check it wired directly to the modem--slower speeds (both under 1mbps). I contacted ATT and after all is said and done, they think there "appears" to be an issue with my dsl line. I'm waiting on the Advanced Tech Support People to call back with their test results and perhaps schedule a service visit.
However, in the meantime, I hooked up our old Netgear Router (WGT624) and it had ZERO issues playing a YouTube video. And, in a speedtest it got speeds of for 2.44 mbps DL and for .44 UL.
So, now I'm unsure what the real issue is...is the DSL line bad? Is it my router? No clue. I'm not sure why an older router would stream videos significantly better than a newer one.
Any experiences with this?
  #16
Old May 26th, 2012, 12:33 PM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
possible router issues if WGT works better.
__________________
"Wireless Tips"
Forum Policy
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
