#11
The WNDR3700 does indeed have a fairly large tftp upload window, making recovery fairly easy.
The worse are some dd-wrt compatible Fry's $19-$29 routers. They have half second tftp upload windows. The USR5461v1 also had half second tftp windows, requiring upto a dozen tries before I successfully put dd-wrt on it. Hence, a batch loop with quarter second pings, I can recover it in no more than 2-3 tries. |
#12
i tried to reload the firmware as said in this post.
tftp says file uploaded successfully but on router nothing happens. Green light keeps bilking and ping to 192.168.1.1 gets stopped. |
#13
Sounds like brick unit now. I would consider replace the unit
__________________
VPN Case Study (www.vpncasestudy.com) Our Second To None VPN Related Setup Case Study "One Stop Solution To Your Netgear VPN Connectivity" *Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support] Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin" "Wireless Tips" Forum Policy June Mizoguchi-i....@vpncasestudy.com |
#14
I also have a similar issue as sanketgroup
Tried to reload various versions of the firmware using tftp. file upload is successful each time, after a minute the WNDR3700 reboots however comes up with the green light still blinking. I can ping the router, webGUI is however inaccessible. Any suggestions? Thanks |
#15
sounds like you got bad router if TFTP with different firmware still has same results
__________________
#16
One last thing to try is a serial 3.3v connection to the router... if you can get it connected, then it is not bricked.... if can't, your bootloader is toast... the wndr3700 has a jtag port and you can ask someone for a copy of their bootloader to flash onto the router... Nowdays, whenever I have a chance I always make a whole flash & a partial/bootloader backup, in case I screw things up. For me, it is faster than an RMA & cheaper than a replacement. It can take hours if your not familiar... I'm assuming you only have firmware issues & not toasted caps or other hardware failures... in the end, it may not be worth your time...
#17
Which port on the router?
#18
You'd pop open the case cover and locate the GND, VCC, TX, & RX pins... I use an FTDI-chip based one, it is much more reliable and most computer no longer have serial ports... it safer also... it must be a Serial TTL/USB TTL, DO NOT get the +5V version, only the 3.3V... I have the "TTL-232R-3V3-AJ", since I can solder a jack on the back of the router for easy access OR create a set of jack+cables for each type of routers... those were the days
But that version is rarely ordered by people, so it is often back-ordered... People order the more fragile version which connects directly on the motherboard....
#19
Quote:
| Thread Tools | |
| Display Modes | |
