#11
Old May 11th, 2012, 10:18 AM
aboese aboese is offline
Junior Member
NETGEAR Newbie
aboese is on a distinguished road
Default Re: WNDR 4000 as Repeater
Quote:
Originally Posted by jmizoguchi View Post
yes........ if you use ethernet cable then only follow the
http://kb.netgear.com/app/answers/detail/a_id/965
rest post other than above does not applied to you for using two router using ethernet cable
I have tried with cables, without cables, I have tried everything listed above and nothing is working. What am I missing?
  #12
Old May 11th, 2012, 10:30 AM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Senior Member
NETGEAR Fanatic
jmizoguchi is on a distinguished road
Recent URL is to use with Ethernet cable only and other setting should relates to repeating should all deleted
__________________
VPN Case Study (www.vpncasestudy.com)
Our Second To None VPN Related Setup Case Study
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
Most Other Useful Docs -"General Technical Documentation", "Router Reset", "Router Setup", "Print Server Tips", "Remote Admin"
"Wireless Tips"
Forum Policy
June Mizoguchi-i....@vpncasestudy.com
  #13
Old May 11th, 2012, 10:58 AM
Junior Member
NETGEAR Newbie
OK, I am rethinking this because I can't get it to work, I have a question.
Can I have four different wireless routers, all with the same SSID broadcast and same security key, but different IP ranges (for example 192.168.1.x, 192.168.2.x, 192.168.3.x and 192.168.4.x). That way I can configure them as wireless routers, but still allow my guys to walk around the office and not have to connect to a different wireless SSID with a different key. They would just get an updated IP Address.
  #14
Old May 11th, 2012, 11:08 AM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
Same SSID and encryption.
__________________
"Wireless Tips"
Forum Policy
  #15
Old May 11th, 2012, 11:09 AM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
wrong IP
192.168.1.2 AP1
192.168.1.3 AP2
192.168.1.4 AP3
IP should be OUTSIDE OF DHCP RANGE
__________________
"Wireless Tips"
Forum Policy
  #16
Old May 11th, 2012, 11:11 AM
Junior Member
NETGEAR Newbie
So that should in theory work without creating a network storm?
Do I daisey change the routers using the WAN ports or do I configure it one on my network?
  #17
Old May 11th, 2012, 12:21 PM
jmizoguchi's Avatar
Senior Member
NETGEAR Fanatic
ALL LAN PORTS ONLY.. there is NO WAN are used for single network design just like the URL
__________________
"Wireless Tips"
Forum Policy
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
