#31
Old July 7th, 2012, 03:39 AM
Slosh Slosh is offline
Junior Member
NETGEAR Newbie
Slosh is on a distinguished road
Default Re: NeoTV-550 Firmware Update (latest: 3.2.27)
Quote:
Originally Posted by Ivanhoe_pl View Post
DLNA still doesn`t work with flac files
I'm using a 2TB USB HDD connected directly to my NTV550 but I have tried MediaMonkey4 and foobar2000's UPnP servers and both serve FLAC perfectly (including high resolution multi-channel). You can also try dBpowerAMP's Asset UPnP server. All three I mentioned are freeware.
  #32
Old July 8th, 2012, 08:18 AM
Ivanhoe_pl Ivanhoe_pl is offline
Junior Member
NETGEAR Newbie
Ivanhoe_pl is on a distinguished road
Quote:
Yes but the problem is i`m not using my computer as a server, but ReadyNas Duo. I`ve tried Twonky7 and oryginal ReadyNASDLNA but both doesn`t work. The problem is i can play flac from foobar (as play to) but i can`t play them via BubbleUPnP or directly from NeoTV550 from DLNA server.
  #33
Old July 10th, 2012, 12:34 AM
Tinitus Tinitus is offline
Junior Member
NETGEAR Newbie
Tinitus is on a distinguished road
Quote:
Originally Posted by yan73 View Post
And what about this joke?
this is the end
  #34
Old July 10th, 2012, 04:24 PM
Kyo Kyo is offline
Junior Member
NETGEAR Newbie
Kyo is on a distinguished road
...Also, the "/N" and "/i" in ssa/ass subtitle files is still wrong in some subtitle lines.
  #35
Old July 12th, 2012, 05:52 AM
brucesee brucesee is offline
Junior Member
NETGEAR Newbie
brucesee is on a distinguished road
I'm attempting to use Asset. My files are stored on a networked server. So far, even after the update to the "final" firmware, not much luck. The Neo "sees" Asset and I can browse my full library. But, the only files that play are MP3. The vast majority of my files are FLAC and - while I can see them and even browse to them on the Neo - they don't play. After I browse to them, they display as 0 m 0s. As for the MP3 files that play, they pretty much crap out after a few minutes. In other words, the Neo still seems to be dropping DLNA, meaning the device doesn't do what it'd been advertised as being able to do.
  #36
Old July 12th, 2012, 07:34 AM
Junior Member
NETGEAR Newbie
Okay - an update. MP3 is now playing properly. And, if I transcode my FLAC files to stream as WAV, they also play properly. Why the Neo won't play FLAC via DLNA/UPP, I've no idea. I've no problem playing FLAC via NFS or SMB.
  #37
Old July 13th, 2012, 04:34 PM
Junior Member
NETGEAR Newbie
Another update. This doesn't impact my uses of the Neo, but, on other forums, users have noted that installing the latest (final) firmware impedes playback of BD iso's. And, from what they say, rolling back to the prior firmware doesn't rectify the situation. Perhaps NetGear has added Cinavia (though, the release notes make no mention of that).
  #38
Old July 13th, 2012, 06:48 PM
Junior Member
NETGEAR Newbie
I haven't had any problems playing back blu-ray ISO files (uncompressed) with this firmware. All of my uncompressed rips are on an attached HDD. I haven't tried over my LAN (wi-fi from the PC to the router), however.
  #39
Old July 14th, 2012, 02:32 AM
StephenB StephenB is offline
Senior Member
NETGEAR Fanatic
StephenB is on a distinguished road
Quote:
Adding Cinavia wouldn't target BD ISOs exclusively, (and it would be unlikely anyway given the eol status of the product). So I don't think that theory is right.
Can you post a link to the "other forum" on the BD iso issue? I'm not seeing it in google.
  #40
Old July 14th, 2012, 05:54 AM
DMJ's Avatar
DMJ DMJ is offline
Junior Member
NETGEAR User
DMJ is on a distinguished road
No BD Iso issue either over lan or on usb device.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
