#11
Old November 17th, 2012, 03:25 PM
Simon0 Simon0 is offline
Senior Member
NETGEAR Expert
Simon0 is on a distinguished road
Default Re: How to configure a WNDR3700 (N600) router on a 2Wire 3600HGV modem
2Wire 3600HGV is a U-verse Gateway which does NOT allow bridging at all... It has limited connection tracking abilities, and it'll track them no matter how powerful a router you attach to it. You can attach a router in AP-mode (easiest), but I prefer using the DMZ-plus mode. Reduce udt/tcp timeouts if you need more connections for game server refresh/p2p/server access/etc...
Goto 192.168.1.254 | Settings | Applications, Pinholes and DMZ | Allow all applications (DMZplus mode)
For local servers, you MAY need to properly setup "Advanced Configuration" as well but BE CAREFUL... The ip is pretty much static...
good luck..
  #12
Old December 20th, 2012, 07:45 PM
jay5 jay5 is offline
Junior Member
jay5 is on a distinguished road
I am having an issue with a similar setup.
I have the 3801HGV 2Wire from uverse, and the N600. I set up the N600 as an AP (turned off DHCP - worked fine when I had comcast and a motorola surfboard modem and a Rangemax router).
My wired devices (Xbox, deskop PC, Uverse boxes) seem to be working fine and have good internet speed.
My wireless is extremely poor. It cuts in and out, and is slow when it is working. I can't figure out what is causing this... I disabled the wireless network on the 2wire, and that had no impact.
Any suggestions?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
