#31
Old March 7th, 2013, 10:31 AM
sparks003 sparks003 is offline
Junior Member
NETGEAR Newbie
sparks003 is on a distinguished road
Default Re: Remote Home Surveillance Cameras Monitoring not working
Apologies, yes it works fine on my lan wired and wireless even on my iPhone3 when in wifi. Just not remote as the ports didn't open.
Also, I'm using a different DVR system, Defender is the brand.
  #32
Old March 7th, 2013, 04:41 PM
jmizoguchi's Avatar
jmizoguchi jmizoguchi is offline
Junior Member
jmizoguchi is an unknown quantity at this point
This port 9000 from the mobile phone. Who you are access it
  #33
Old March 8th, 2013, 07:44 AM
fordem fordem is offline
Moderator
NETGEAR Fanatic
fordem is on a distinguished road
How is the ip address on the DVR configured? If DHCP, is it a reserved address? If static, do you have a default gateway entry?
__________________
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
  #34
Old March 8th, 2013, 04:07 PM
Junior Member
NETGEAR Newbie
Yes mine works on the LAN but not WAN or outside my router. If it is my ISP would dyndns help me out?
  #35
Old March 9th, 2013, 02:43 PM
Junior Member
NETGEAR Newbie
Ok, I tried DynDNS and it did not help.
My ISP just bridged their router and mine and gave me a static IP.
My DVR IP is set to static with it's IP as 10.0.0.3, gateway to 10.1.2.9
10.1.2.9 is the static IP I set in my router that the ISP had me set it to.
I still see my external IP as 199.96.245.37, that part I do not understand. However I am rebooting and trying different things with it as I type this.
I apologize for jumping in on this thread, I think I should have started another hopefully it will help more than one person.
  #36
Old March 9th, 2013, 03:07 PM
jmizoguchi's Avatar
Junior Member
Quote:
199.96.245.37
this has to show on netgear router's internet port or it will not work
  #37
Old March 10th, 2013, 12:02 PM
Moderator
NETGEAR Fanatic
I suspect your default gateway address may be incorrect - it should match the LAN ip of your router.
Go to the PC you are using to access this thread, open a command prompt and type ipconfig - set the DVR's default gateway to match the default gateway shown in the ipconfig results.
Edit...
10.1.2.9 is what - your router's LAN ip or WAN ip?
It sounds like your ISP may be issuing private ip addresses, if that is the case you can forget about external access to the DVR, it's not going to happen.
__________________
  #38
Old March 10th, 2013, 12:18 PM
Rodog Rodog is offline
Junior Member
NETGEAR Newbie
Rodog is on a distinguished road
So far, this is what works and doesn't :
- IPhone 3 and 5 : LAN no , WAN no, DDNS no
- PC's - LAN yes, WAN yes, DDNS yes
BOO BOO KITTENS
  #39
Old March 10th, 2013, 01:42 PM
Moderator
NETGEAR Fanatic
Rodog - you most likely have a misconfiguration between your DVR and the iPhone app - if you can't get it working on the LAN it won't work on the WAN, and DDNS is just a way to locate it.
Start by determining what ports the DVR uses and configure those in the iPhone app.
__________________
  #40
Old March 11th, 2013, 10:28 AM
Junior Member
NETGEAR Newbie
Fordem and June, you were both right, I had my IP and Gateway numbers swapped.
I did not have all my activex set as the DVR instructions said to.
I also failed to set UPnP to enabled after the last reset on my router.
It all works on LAN and WAN as well as iphone 3 and 4.
I forwarded ports:
8080 - HTTP
9000 - client port
18004 - mobile port.
My ISP got me a static IP, I get lost here one would need to contact their ISP. They also bridged my modem (RF modem router) to my router.
I will go back and try to figure out Rodog's in the next few hours, have to go to work for a while.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
