#11
Old May 30th, 2013, 11:14 AM
Joe_ Joe_ is offline
Senior Member
NETGEAR Addict
Joe_ is on a distinguished road
Default Re: 5Ghz connection dropping
I agree with fordem. It should be a simple enough test to get closer to the router (maybe 2 meters) and in a direct line-of-sight. Does the same thing happen then?
  #12
Old June 1st, 2013, 10:02 AM
Tonymustang302 Tonymustang302 is offline
Junior Member
NETGEAR Newbie
Tonymustang302 is on a distinguished road
After doing a lot of hard research.....and deciding on this router....still drops 5ghz and regular signal after 5-10minutes. Have to reboot...then still same problem. Moved router around everywhere still same issue. Using newest firmware update.
Im about to return this POS. When it works I love it but only for the 5-10min it works.
  #13
Old June 1st, 2013, 04:45 PM
fordem fordem is offline
Moderator
NETGEAR Fanatic
fordem is on a distinguished road
Tonymustang - you have a different problem - I suggest you start your own thread (or return the router)
__________________
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
  #14
Old June 1st, 2013, 11:16 PM
LPD1964 LPD1964 is offline
Junior Member
NETGEAR Newbie
LPD1964 is on a distinguished road
Omving iPad or Windows computer around the house does not wove the problem. According to Netgear the problem is connecting the router to the KPN V8 modem/router. Netgear's advice is to disable all router functionalities and DHCP on the KPN V8 and try if this is solving the problem.
Unfortunately this is not possible.
Strange thing is with a Linksys Router I d not have this problem.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
