#11
Old February 17th, 2014, 06:19 AM
LeeH's Avatar
LeeH LeeH is offline
Senior Member
NETGEAR Expert
LeeH is on a distinguished road
Default Re: R7000 Unreliable
If you can connect after doing a reset you might want to reserve all your IPs in the router. I used to get disconnects due to IP conflicts before I reserved my IPs in the router. I have one static IP outside the DHCP range and it is reserved too. I truncated the DHCP IP range to .2 ~ .199 and set the static IP at .200
My cell phone used to be really bad at hopping IPs every time I left and re-entered the house. It now always gets the same IP. The router is bad about reusing IPs that are already in use without IP reservations. Reserving IP addresses in the router solved my problem.
  #12
Old February 17th, 2014, 06:42 AM
Temporel Temporel is offline
Member
NETGEAR User
Temporel is on a distinguished road
fang,
I never had any of those problems since I bought my router. Yes the sitiation was far from perfect on day one, but since 2 or 3 betas ago, Im very happy with my purchase.
Note: You really need to do a factory reset before and after flashing a new beta firmware even if that sounds strange to you.
  #13
Old February 17th, 2014, 09:35 AM
RogerSC RogerSC is offline
Senior Member
Advanced NETGEAR Expert
RogerSC is on a distinguished road
Quote:
I've been using a static IP on my phone for some time now. Doing that also uses less battery for WiFi since you don't have all the DHCP activity going on. Seems to work well.
  #14
Old February 17th, 2014, 10:40 AM
Lexist2112 Lexist2112 is offline
Senior Member
Advanced NETGEAR User
Lexist2112 is on a distinguished road
Thumbs up Re: R7000 Unreliable
RogerSC,
Exactly
  #15
Old February 17th, 2014, 02:43 PM
fang fang is offline
Junior Member
NETGEAR Newbie
fang is on a distinguished road
I performed a reset and went through the configuration again. I've backed up the config and the router is working for now. I don't have much confidence that it will keep working. I've be through this multiple times now.
Thanks for everyone for your suggestions.
  #16
Old February 17th, 2014, 05:49 PM
Senior Member
Fingers cross...goodluck.
Keep us informed and let us know if that did the trick
  #17
Old February 18th, 2014, 04:06 AM
JohnNadeau JohnNadeau is offline
Junior Member
NETGEAR Newbie
JohnNadeau is on a distinguished road
@Fang...
I know you said that you're running the "latest" firmware in your original post, but is that the latest on Netgears Download Page or is it the latest Beta Firmware?
So, what is the actual version number that you are running?
Did you try updating to the latest Beta Firmware ? V1.0.3.24_1.1.20 has been working really well for me !
Here's a link to a post in this forum, which has a direct download link from Netgear:
http://forum1.netgear.com/showpost.p...&postcount=103
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
